SOS 3" Pulley - Cut Grooves Photo
Bad idea, all it does is sand down your belt, and if you still have any amount of slip, plan on the belt breaking in no time. You dont want a sand paper surface on a rubber belt.
You will always have some amount of belt slip by design unless its a cogged system, and those have their own set of issues, like breaking things.
Here is a little bit of it
"While the coating sounds like it may be harsh on the belt Towns says they actually tested it thoroughly on a supercharged Mustang for a few years prior to offering the service to enthusiasts. “We ran the same belt for a couple of years, took the car to the track, drove it on the street, etc.” That car was on a ’03 Cobra that had its blower pulley machined smaller than anything commercially available so that the Carbinite crew could test their coating on a pulley that offered minimal surface area. “This was a litmus test. Minimal amount of wrap angle and surface area, maximum blower RPM.”
I have not used one of these pulleys (Carbinite) but I do have many years with a cut pulley(2.9"), and the cut pulley ate my belts way faster than a standard made 3" pulley. Stock for my car was 3.8". For around $100 I wouldn't hesitate to try one. But I'm an old hot rodder that likes to try new and old hot rod tricks on my cars. If it works, great if not I'm out a pulley and $100, thats cheap in my book.
Rod
Did you read the article?
Rod
Rod
The Carbinite coating has been tried several times by members on the CTS-V forums with the same belt-destroying results. Cut pulleys are a similar, though less harsh version which will also eventually eat your belt. The rubber formulations are designed to grip smooth sheaves.
There are really only two ways to increase the grip that the V or multi-V belt will have on a given size of pulley without drastically shorter life: Increasing tension (which has it's own problems elsewhere in the system) or increasing surface contact area (more ribs/belt wrap).
Edit* If you are interested in modifying your supercharger drive, we offer free tools and design tips on the Gates website. Example: https://www.gates.com/us/en/resource...gn-IQ-software
Just run a bigger crank pulley so you can increase the size of blower pulley to maintain desired boost if its a big issue. I never had a problem with a 3.2, but did have minor slip in 1st gear due to the rate of engine spool up, but didnt matter because the tires couldn't handle it regardless. 1st gear is unless when you get up over 400whp. 2nd gear i want full belt grip and did. I cross cut my own grooves on a custom 2.7" pulley I ran on my old NV1000 for a period of time before moving to the 1200.
Dont recall exactly, like I said I never had to run one because I had no slip issue with a 3.2, but some have and there is info on this if you do a basic search. Its going to be similar to a vortech system because they run a larger 6" crank pulley. Its likely going to be moving to a 3.6"- 3.8" sc pulley combo. I believe you can run up to a 6.5 crank pulley before there is water pump interference. That will put you even larger on the sc pulley.
The 3" pulley was slipping a bit on the dyno past 8k RPM, but I tightened it a bit more and it seems OK on the street. I'll get the laptop connected soon and get a log of boost through the gears to check, though. If I'm still losing boost, I'll pick up a Dremel and get some cutting done.
99SH
04-29-2013 03:37 PM
