Sos paxton novi 1220 s/c leaking oil ?help
Old 06-25-2014, 08:36 AM
s2k-fc3s's Avatar
Default Sos paxton novi 1220 s/c leaking oil ?help
Hello everyone thanks in advance for any help ..A little about the car have a sos kit with novi1220 3.2 pulley plm front mount intercooler kit,hks bov ,id1000 ,aem 320lph,aem EMS v2 making 375whp .. My questions are my blower is leaking a little oil from the inlet where the filter goes mostly when am boosting and spraying oil all under my hood the filter itself is wet with oil and when I pull it off there oil just sitting there in front off the propeller??? Is this normal guys?
Does this mean I need a rebuild new oil seal etc etc???
Where is the best place to call and send for a rebuild ?
Should I just upgrade to a 1200 while am at it and get a retune?
Thanks
Old 06-26-2014, 06:41 AM
1nate7's Avatar
Not normal, sounds like a bad seal. I'd start by calling Paxton, they can give you price for a rebuild and what it would take to convert to a 1200. If you just wanted to do it yourself, the seals aren't that expensive but the problem is finding part numbers/availability. There are some for sale here but I'm not sure exactly what you would need:
http://www.superchargerrebuild.com/paxton/
Old 07-03-2014, 06:50 AM
s2k-fc3s's Avatar
Originally Posted by 1nate7
Not normal, sounds like a bad seal. I'd start by calling Paxton, they can give you price for a rebuild and what it would take to convert to a 1200. If you just wanted to do it yourself, the seals aren't that expensive but the problem is finding part numbers/availability. There are some for sale here but I'm not sure exactly what you would need: http://www.superchargerrebuild.com/paxton/
Thanks for the help I have a fmic with the blower with and hks bov I suspect maybe the bov is not meant for this kit so am going to switch for a Tial with supercharge spring see what happen.
GoOn3
06-21-2011 04:56 AM
s20004lifehomes
11-19-2009 04:53 PM
HvRRZ
10-07-2008 10:26 AM
GGSi345
04-12-2008 11:23 PM
kstokell
08-31-2004 04:16 AM
Quick Reply: Sos paxton novi 1220 s/c leaking oil ?help
