SOS Supercharger Kit FAQ Sticky
#1381
Thank you for the response. Does the SOS kit come with the water pump or this something I need to purchase seperately?
I don't see an option to purchase the pump from SOS directly which is why I am trying to figure out if its already included as part of the SC kit or Heat Exchanger.
#1382
hi Muffin Man any good results on your 3 inch pulley on your supercharger. I'm planning to run that set up with my Paxton 1200 . Any belt slip? I also was researching on ASP company that makes custom crankpulley for our car with more belt wrap on the pulley.
https://www.s2ki.com/forums/s2000-fo...1152994/page4/
Base map for the ID1000's is ready to go
#1385
Anyone using the In-tank Fuel Pressure regulator offered by SOS for the 06-09 returnless fuel systems found here: https://www.scienceofspeed.com/index...000-06-09.html
Plan on going with a 3.4" pulley (14.5 psi) on 93 pump gas and a Walbro 255.
Just wondering if anyone has had any success or experience with this unit and if its worth it. Its only about $45
I am trying to avoid having to make any serious modifications to my fuel system.
#1386
#1387
Yes I installed it. Also have 3.4" pulley. Had a Radium surge tank and pulled it for some other reasons(long story). While I was doing that I installed the SOS piece in my MY06. I really do not have a before or after on injector duty but all I can tell is that I have no issues running the same set up you have.
#1388
