SOS Supercharger Kit FAQ Sticky
Old 01-11-2019, 11:52 PM
  #1461
s2000Junky's Avatar
I never had belt slip with a 3.2" and standard 5.45" crank pulley.
Old 01-12-2019, 07:24 PM
  #1462
Lex
Lex's Avatar
Well, as you can see their seems to be some contradictory information here.. lol
Maybe I should lead with the following question:
Who has experienced belt slip with a a 3.2"pulley and who has not???
Old 01-12-2019, 08:16 PM
  #1463
s2000Junky's Avatar
Start a poll
Lex (01-14-2019)
Old 01-13-2019, 12:43 AM
  #1464
hecash's Avatar
I've been running a 3.2" pulley for 5+ years now without any issues. Get a belt tension gauge and set your belt tension to 125lbs and that ought to keep it from slipping. I replace the tension pulley bearings every couple of years as a preventive measure because it's low cost with high insurance value. Having said that, I'm reminding myself to do that again this year. It will be my 6th.
Lex (01-14-2019)
Old 01-13-2019, 06:10 AM
  #1465
jdmz's Avatar
In my experience it was the belt that helped with the 3.2" pulley. With the gatorback I was never able to get it to not slip without putting too much tension on the line. The dayco belt I got from advanced auto parts worked alot bettor.. Only one tightening and another one after it breaks in.
You may want to try the new Gates RPM belt that has good reviews.
Lex (01-14-2019)
Old 01-14-2019, 04:33 PM
  #1466
Lex
Lex's Avatar
Originally Posted by s2000Junky
Start a poll
Glad to hear that! I actually do the same as a preventative measure. Are you running any special fuel like methanol or e85? Or have you been on just regular pump gas? Reason I ask is b/c I just read on the S2000 Facebook pages that anything smaller than a 3.4 pulley is not safe on pump gas. Is this true?? lol
I really want to throw on a 3.2 pulley but not trying to deal with any headaches on additional fueling modifications. FYI, I have a 2006 so its the returnless fuel system.
Old 01-14-2019, 04:36 PM
  #1467
Lex
Lex's Avatar
That's interesting. Always heard to go with a gator back to help prevent belt tension. I will look into this, thanks!
Also, are you on regular pump gas (i.e., 93)? What kind of PSI are you seeing with your 3.2" pulley?
Old 01-17-2019, 04:58 PM
  #1468
jmmay's Avatar
Has anyone tried a v-mount setup with this kit yet? How did it perform and did you use a intercooler or just the heat exchanger.
Old 01-20-2019, 06:57 PM
  #1469
jdmz's Avatar
​​​​​​I'm only seeing 13 psi because I'm in Denver.. 5300+ ft elevation. Running 91 octane. I got old stock gatorback so that may have contributed to the slipping but another forum member recommended the dayco poly rib and it has been flawless.
EDIT: I actually have a 3.4" pulley
Old 02-21-2019, 08:12 AM
  #1470
kjdm7's Avatar
After reading all 147 pages of this thread, I've decided to pull the trigger on a Stage 2 kit for my 2006. I have one last issue that I can't figure out though. For engine management, SOS supplies the KTuner EMS instead of Hondata FlashPro. From what I can tell, tuners seem to prefer the FlashPro. I've talked to a local tuner who can do KTuner, but even he seemed more comfortable with FlashPro. So I'm wondering if anyone's got experience with KTuner? Should I stick with whats supplied or ask SOS to send me a FlashPro instead???
Quick Reply: SOS Supercharger Kit FAQ Sticky
