SOS Supercharger Kit FAQ Sticky
#1481
Quick update -- I was finally able to get the SOS stage 2 kit with 1200 blower and 3.8 pulley installed. Having fueling issues over 7k, and the tuner suspects fuel pump issue (running what I believe is a walbro 255 installed by previous owner). Before the fuel issues, the car was at about 350ish hp and 250tq at about 7k rpm on a Mustang dyno. Tuner limited revs to 7k until I get a new fuel pump and we get the tune finished
Compared to my the old kw kit, the car seems to run more smoothly across the entire RPM range. The "coffee-grinder" sound from the blower is taking a little getting used to, but its overall more quiet than my rotrex setup. I'll have a more complete numbers once the fueling issues are solved and tuning is complete, but I am enjoying the SOS kit so far.
#1482
ap2 redline. finally got everything sorted, turns out i'd been running the stock fuel pump all this time... also, was making "only" about 360hp 240tq with a few misfires until the tuner checked the spark plugs, which were toast. new set of plugs and the final numbers are 397hp and 260tq. very pleased with how its all come together.
#1483
Not sure why the sticky was removed from this thread so sorry for bumping this.
I was just wondering if the tensioner pulley is a generic available part or you need to get the bearing separately if you want to change it.
I think I got a bad one, oh and is there a torque specs for this?
#1484
http://www.youtube.com/watch?v=CZbeyMXVz10
Torque spec? Probably, but considering you need to loosen the tensioner bolt on the pulley when adjusting tension, and the only way to tighten it again is with a box wrench, I'd say tight is tight.
flanders (07-07-2021)
#1485
Thanks, seems not that easy to find over here in Europe though but I'll just ad it to the US shopping list
Looks like Gates 38015 is an equivalent, if anyone found a better quality one please share.
jefferyg32
Member S2000 Classifieds and For Sale
18
05-04-2011 09:29 PM
