SOS Supercharger Kit FAQ Sticky
#471
I don't know what the stock readings are but mine are around high 70-80 psi under WOT. 30-50 psi cold start idle and 15-20 psi warm idle.
#472
Originally Posted by Picturepro' timestamp='1359598126' post='22304125
I just got my car dialed: 382whp, 242Tq, 11.75# boost at 8500
SOS stage 2, 1200, 4.0", Sideways intake Cam adjust -2˚,upgraded H.E.
T1R dual exhaust
if you are in a state where 93oct is readily available or you are running E85 you might have probs with 3.8"
T1R dual exhaust
6000rpm the tires loose traction, 245 just dont work Hope the 255 hold better
#473
Originally Posted by Rubn1out4GudLuk' timestamp='1359650419' post='22305223
[quote name='Picturepro' timestamp='1359598126' post='22304125']
T1R dual exhaust
T1R dual exhaust
[/quote]
I hope it works out for you, man. Good luck in your pursuit of traction(It's always something in a boosted car =P)
#475
Originally Posted by Topplayer' timestamp='1359665522' post='22306044
does anyone have oil pressure readings? wot, idle,ect should the oil pressure be less than stock because of the line to the blower?
side note. my clutch is broken in now THIS CAR PULLS!!! love the sos kit! I dont rev it out past 8k on the street its already way to fast. Cant wait to take it on a road course in a few months
#476
#477
Originally Posted by s2kslav' timestamp='1359811834' post='22309763
Guys, with a 70mm TP and single exhaust, does the s/c add exhaust db's? Basically should I expect my exhaust to be louder after the s/c install?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
#480
I run stock exhaust and TP. It is certainly louder in general than without the SC installed. Between my Tial Q, the whistle of the SC at idle, and the extra vibrations passed from the SC.
