SOS TS-MAX Gen2?
This all sounds really impressive. Who’s planning on buying?
love to see a writeup for install and testimonials.
Does anyone think this will make the SC kit obsolete? Seems like a better option and only $1500 more.
it’s seems to not mention clutch and I know ours can’t handle +150hp
This winter I'm coming back to the Honda and giving it some TLC. Fixing the downpipe clearance and making a nice quiet 3" to dual 2.5" exhaust. Got myself a TIG welder to play with.
Probably finally install the AEM Infinity as well, unless the new SOS Link ECU setup looks that compelling to switch.
Really, interesting. I'd think something like a G30-770 would flow well but maybe it's a little too big? Definitely nice to simplify things with an IWG and less exh plumbing but they probably did it for good reason. Been following your Porsche build, good stuff, you miss your Honda?
Probably finally install the AEM Infinity as well, unless the new SOS Link ECU setup looks that compelling to switch.I think SOS tested a regular rotation IWG G-series. The tight manifold bends to make that fit will kill the top end power and they had very specific power targets they wanted to hit. Maybe they used reverse rotation. Either way, when I looked at it, I couldn't figure out a good way to make that internal wastegate fit without compromising the manifold design and flow. I think SOS ran into the same issue trying to make the IWG work with the G-series. That all said, this new setup from SOS uses an external wastegate mounted to the turbine housing.
They chose different compromises than I did. I think they designed to work with the factory engine mount and their oil filter relocation thing, and I think a custom heat shield. I made mine work with the factory heat shield, hasport engine mount, and a total oil filter and cooler relocation.
This new SOS setup does look to me the best made yet for the S2k that's pretty much a bolt-on solution.
I miss the responsiveness of my old s2k turbo setup. Haha. I hope to get the Porsche there; it's a matter of time, money, and if I want to use something bolt-on or something custom like I did with the s2k. The hard part with custom, aside from costs, is the Porsche is my daily driver, so no downtime. Raggdoll will have a bolt-on solution that would meet my performance goals, but some compromises on track robustness potentially. Streetcar, their solution is a no-brainer.
Responsiveness in terms of throttle response or turbo..? One thing I'm sure you don't miss is the rougher street nature of the s2k. Being a convertible it's definitely loud and much less "refined" than a porsche but I guess that's part of the fun too. Newer porsches are just so darn comfy imo.
One thing that caught me off guard, but makes total sense, is that the Cayman with strut suspension rides much rougher with full spherical bearing suspension. With the strut, the loads are transmitted straight into the chassis. Plus, I'm running around 9.5 deg of caster, so the angle of impact really sends the jolt straight into the chassis. My S2k with the full spherical Blacktrax setup was much smoother over the same roads owing to the S2k having the control arm setup.
I looked up the turbine housing from Forced Performance used on this new SOS setup. It's not twin-scroll which was slightly surprising. But it would have been a much more expensive turbine housing casting if it were twin-scroll.
ScienceofSpeed RR-MAX Turbocharger System - S2000, 2000-09
NYCS2
Oct 24, 2006 10:28 AM
