Spal fan
Hi,
I installed a single spal extreme radiator fan a while ago. But it seems that the original fuse and relay won't work with this fan. I think it needs more amps than the fuse can handle. When the engine is off, and I manually switch the fan on via my laptop (aem ecu) I do hear the realy clicking... but I think the fuse is allready gone. What kind of relay and fuse do I need for this fan? And where can I buy one? Thanks! Jasper |
SPAL Extremes run off a special HO relay w/ 40 amp fuse (PN: FRH-HO-KIT).
spal extreme performance fans need a special high output relay as well as a special harness and fuse kit that lets you wire the fan straight to the battery. You will also need a fan soft start controller to control the fans so that they dont start at 100% power and stall your engine.
here are the 3 things you will need this is the spal high output relay with the wire harness http://www.ebay.com/itm/NEW-SPAL-HIG...lWgqyw&vxp=mtr This is a fan control you will need so the fans dont stall your engine when they start. http://dccontrol.com/constant_temper...ontrollers.htm |
Do these fans draw so much amps that it will stall the engine when it comes on? :blink:
That's pretty sick I have just one 12'' twisted blade fan |
Originally Posted by Jaspah
(Post 24038485)
i also have 2 spal extream fans and they will stall the engine when they kick on from off to full 100% on. You will need either a capacitor or some type of soft start fan controller than do not start the fans at 100% power. I have done both and i recommend the fan controller from www.dccontrol.com This will start the fans at 10% power and will slowly add power as the water temp goes up.
Has anyone tried the spal brushless fans? Supposedly they have a soft start built into them. I don't know if they can be controlled by just a relay (on/off), or if they need a pwm signal. But they have been out for a couple years, but I can't find too much info on them.
Is a soft start also needed with just one fan?
(Post 24039263)
Ok, I will fix something than. Thanks!
| All times are GMT -8. The time now is 11:15 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
