The Spectacle's Turbo (Re)Build *Round 2*
#22
Originally Posted by spectacle,Jan 24 2011, 02:57 AM
The 4.10 has me going into 5th before the traps and it is hurting me. I guess I should have asked this before committing to it but can you hold 4th before passing the traps with the 3.91 gear?
Hitting 5th was like hitting a wall.
#24
Originally Posted by slappynuts,Jan 24 2011, 10:48 AM
Any boost creep?
But for normal driving around town, no issues.
#25
Great read.
I have very similar power output with and 1/4 mile times at the drag strip. 12.3 on street tires. I'm currently running a puddymod diff with a 4.3 I had back in my Supercharged days, but now its just too short for the turbo setup. I'm very interested in hearing your future review regarding your track experiences with the 3.9FD.
I've also love to get some more details on how you've braced your manifold if you don't mind sharing. Thanks!
#26
Wow thats a trick setup . The harmonics you speak of are no different with the supercharged crowd and i doubt that you will ever get away from that . Im curious about the underhood temp readings but we shall see in the warmer months . Best of luck man !
#27
dude, your pockets are deep...not many people could have stayed with this like you have. I really hope it runs good when you get the new diff in...much respect for your patience.
#28
good re(build) thread! I've gone through the same issues that you have over the past few years and have done similar things to prevent cracks (ie. 3.91 puddy diff, cracked manifolds and down pipe and dump tube). I found i was able to lower resonance by utilizing the stock tranny mount brace that is used on the OEM header on my down pipe. Also, if you hear lots of vibrations, at specific RPMS, it is usually something that has cracked and is vibrating.
#29
Looks like the sidewinder, wastegate and diff where the main problems... I feel for you. Good work on staying with it! They car sounds great.
So basically, our diffs are crap? What are you getting from Puddydaddy, a stage 2?
#30
Are diffs are fine. Nothing will survive severe wheelhop. I'm only getting a 1.5+ from Puddy.
