S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   starting issues (https://www.s2ki.com/forums/s2000-forced-induction-142/starting-issues-625559/)
spiffey28694 Aug 24, 2008 04:40 PM
starting issues
I can get my car to start but the #3 cyl will not fire. Checked the plug and it is not wet so i have switched injector placment that did not make a diff so i replace the plug plug wore coil replaced fuel filters checked plug volt it is at 12.0 volts where it should be so what the hell is keeping the #3 cul from firing the plug and the injector has juice. The thing that baffles me is that the plug is not getting wet with fuel. also done compression check on all 4 cyls and they are the same. Im stumped!!!!!!!! :banghead: The only thing that i could even begin to think of would be that the ems is not sending a signal to fire the injector to pulse. any help would be nice and greatly appreciated. already called my tuner but it will be 3+ months b4 he can get me in.
spiffey
2big4aS2000 Aug 24, 2008 06:04 PM
where did you get your base map, seen this problem if you load a base map from a 1012 vs a 1052, update your software on your laptop, then update firmware on your ecu, recheck firing order degrees. had same issue thought car was out of time, bad injector, bad coil, but changed ecu and ran fine, put back ecu and did as described above - now runs perfect @ 480 hp w inlinepro kit on 880cc injectors.
© 2026 MH Sub I, LLC dba Internet Brands
