Stewies Candy swirl FBM V2 build
Old 06-28-2017, 02:19 PM
  #101
MorngWoodStewie's Avatar
Originally Posted by honda85
Haven't finalized my install yet. Just researching what other members are using. Im thinking of 50psi or 60psi with vaccum off.
its all trial n error, what works for me might not for you. I think you'll be fine with any of them honestly lol. As long as it's tuned around it's behavior and it's acting right in boost and has a consistent base every start you should be good :thumbup
consistency is your friend.
Old 07-07-2017, 02:56 AM
  #102
Since i have begum to settle down in Kansas. Im waiting on my fuel card from capital oil co. For e85 access and started etuning with derf.tuned (IG)
started smoothing everything out and man just some quick adjustments made some improvements already Good stuff!
will be remote dynoing in the near future with the flex fuel portions.
Not to optimistic for 500 with the ID1ks but having some safety with the E making similar #'s with less boost or the same ill be happy.
Thats it for now. Ill Keep it updated
Old 07-07-2017, 08:15 AM
  #103
Memo6453's Avatar
Derf is local to south florida... curious if he works on Flashpro... my mechanics cars he builds normally use him for AEM/Haltech i think. Ive been talking to B.R.I.A.N. from Brian tuning in miami as well...
Old 07-07-2017, 08:11 PM
  #104
Ya he can tune FP
Old 07-09-2017, 08:51 AM
  #105
honda85's Avatar
Originally Posted by MorngWoodStewie
Thanks! I have the smallest orifice in. Running 70psi at atmospheric and around 65-67 with idle vacuum.
So you're saying that you are on 70 PSI vacuum off and when you hook up the vacuum it's around 65-67? Because I just installed the .200 orifice on my regulator and set the pressure at 60 PSI vacuum off and when I plug in the vacuum it goes down to 40 PSI. Am I doing something wrong?
Old 07-09-2017, 01:27 PM
  #106
Whats it go to when you blip the throttle?
Old 07-21-2017, 08:08 PM
  #107
honda85's Avatar
I set my base pressure at 50 psi and with idle vacuum on is 40. With your ktuner converter do you have to upload the map when you enable the flex field option to show ethanol percentage. I am having trouble showing ethanol percent when I enable the flex fuel option.
Old 07-21-2017, 08:10 PM
  #108
honda85's Avatar
Trying to figure out how to work this thing
Old 07-21-2017, 08:24 PM
  #109
varry nice! (Borat guy)
sooo i never had it not enabled si not sure if it HAS to be to show E percentage. Since the converter is powered seperately and sensor, and ecu pins works regardless. Touch the screen and pick a gauge that allows "layouts" i beleive they all do but some allow you to put more on then others. The ethanol layout tab is on the second page. I always had the flex fuel enabled even when it had 0's for +psi, +timing per E percentage just so i could see how much came in the pump etc. if it reads a 100% or 0% after you flash somethings wrong.
Old 07-21-2017, 08:28 PM
  #110
Unless that far left analog gauge is ur E... sorry kinda got carried away reading your post... yes youll have to flash it. So the converter "converts" but the flash most likely gives it that knowledge paired with the touch to show percentage. This is in theory of course but ya. Are you already boosted? Are tou using there base map?
Quick Reply: Stewies Candy swirl FBM V2 build
