Stock cushions for ID1000?
Old May 25, 2014 | 12:50 PM
volcomboy390's Avatar
Default Stock cushions for ID1000?
I have some ID1000 I need to install but dont have stock injectors to get the cushions from... I have RC650 in there right now... The RC650 will be for sale when they are out too.
Is my only option spending 14 bucks a seal from Honda or does someone have a website to use or even some extras I can buy off of em.... Part # I believe is 16472-P10-A01 correct me if im wrong!
Thanks.
Old May 25, 2014 | 01:19 PM
lude92_si's Avatar
im also looking for the rings on the end of the injectors since mine have dry rotted. but i placed a order for some and thought i got the the rings but when i got them they are cushion rings that fit in the manifold. im guessing these are the O rings that fit on the injectors then seat up to the cushion O rings in the manifold??
http://www.hondapartssales.com/lisle...NTAKE+MANIFOLD
Is this what i need? that will go on the injector? I think is the same thing the OP is looking for?
http://www.hondapartssales.com/lisle...1=&inputstate=
Old May 25, 2014 | 02:36 PM
CoolGuy094's Avatar
The seals that seal the injector to the intake manifold are 16472-P0H-A01. They are like $1.50 a piece. The o-rings that seal the injectors to the fuel rail are 91301-P2F-A01. They are also like $1.50 a piece, but new ID injectors come with o-rings you can use instead if you rather. I don't know where you're getting $14 per piece from.
Old May 25, 2014 | 03:26 PM
lude92_si's Avatar
This is the O ring I'm looking for. The one that's only $2 sits in the manifold and this seals on top of it. These are id725 not sure if that makes a diff.
Attached Thumbnails Stock cushions for ID1000?-forumrunner_20140525_192451.png
Old May 25, 2014 | 07:19 PM
1SlowSi's Avatar
If you send me like $8 paypal gift I'll mail you out my slightly used set of cushions and rings.
Old May 25, 2014 | 10:22 PM
lude92_si's Avatar
So the ones in the pic I posted are a seal o ring? I know there not the lower cushion ones.
Old May 26, 2014 | 04:07 AM
1SlowSi's Avatar
There are rubber seals on the injector along with a metal ring that looks like a ring gear. That seal presses against the OEM seal in the intake manifold. Seal against seal.
Old May 26, 2014 | 05:37 AM
s2klariat's Avatar
^^^ This. Do NOT install ID injectors with the single seal that comes with them. You must use the oem seals as well. You will see what I mean, the seal that comes with the ID will not fit properly into the intake manifold by itself and will leak.
Old May 26, 2014 | 07:57 AM
lude92_si's Avatar
What is the part number for that seal?
Old May 26, 2014 | 11:07 AM
1SlowSi's Avatar
Call T1 and ask for it. If you need the seals and rings I have an extra set but if you need OEM just call Honda.
