Stock vs Comptech Video and NOVI-1000 Pulley Upgrade Questions
When switching from the Comptech factory kit to one with AEM engine management, is it recommended to remove the Comptech FPR and go back to the factory regulator? Or, is it fine to leave the Comptech FPR?
Dang, just placed the order for everything and included the Walbro 255 fuel pump before seeing this.
On a car with 48k miles, should I just get the ACT PP or a new friction disc and release bearing also?
Also, found this article which may help someone looking for similar advice:
https://www.evans-tuning.com/honda-s...ning-checklist
You can use the stock friction disc if it looks to be in good shape and act pp as its a proven combo for more power then you will ever see with this set up. Inspect the throw out and pilot bearing. At only 48k miles id be willing to inspect first and save the money if you dont need.
With a good shape oem friction disc, pilot and throw out bearing you could save about $270.
Yes you should remove it. It will create a lot of tuning inconsistencies and is just not needed any longer at this point. Put the oem fpr back in.
Thanks, appreciate your responses here and in historical threads. Having issues now with long cranking times when the car is hot, so the FPR on the Comptech may be causing issues already.
No issues with starting today. I've also been letting the fuel pump prime for the full 2 seconds before hitting start, so it could be that. Was also having issues yesterday with some power variations at higher RPM that may have been belt slip or fuel issues, but it seems to be running strong today.
I went searching for the ESM and realized I had a spacer under the map sensor that T's off into a few other locations (intake manifold) and also goes straight to atmosphere. From what I've read, this is the original method prior to the ESM.
Are there any known symptoms of using this spacer for MAP sensor signal modification?
What is the afr at wot and idle? Are you running a wideband to check this? Do you even know if the car is running a safe tune at all? There is a fuel adjustment on the comptech rrfpr, but you cant tune it blind.
No, I don't have a wideband. I have one on the way with the AEM Infinity 506, but that's all part of the new system. I think I'll just take it easy on the car for now and stop troubleshooting the Comptech factory system until all of the new parts are on and it's tuned.
That's a smart plan.
MrJohnnyLy
10-16-2013 04:55 PM
MrJohnnyLy
09-11-2013 05:53 AM
