such thing? self lubricating turbos
Old Feb 11, 2010 | 01:47 PM
gilby1kanobie's Avatar
Default such thing? self lubricating turbos
noob ?
not planning on anything for the moment, just curious if they make a "self lubricating turbo"
be sweet if someone would make a "internal wastegate-self lubriating turbo"
if theres one, can someone send me a link.
Thanks
Old Feb 11, 2010 | 01:56 PM
boostedf22c's Avatar
Yeah, it's called a centrifugal supercharger.
Old Feb 11, 2010 | 02:09 PM
i was reading around one day, and i think i read someone writing that theres a oil taped free turbo out!
no tapping, no drilled oil pan,
every once in-awhile change the oil or lube from the turbo wtf
can't be true, right?
Old Feb 11, 2010 | 04:19 PM
Ian300D's Avatar
Stop wasting your time, it's a horrible idea if i've ever heard one. With temps my turbo get's I can't imagine stagnant oil lasting very long at all, and definitively not for a good price.
You should be looking into a quick and easy solution to Vmount our cars.
Old Feb 11, 2010 | 05:44 PM
dsddcd's Avatar
With today's water cooled cartriges, ceramic bearings and lubrication technology this could definatly be a possibility.
Old Feb 11, 2010 | 08:55 PM
jzz30's Avatar
the real challenge to this would be where you would put the pump, resevoir and the cooler + the lines.
Old Feb 11, 2010 | 10:29 PM
NFRs2000NYC's Avatar
While I may be talking out of my ahole, it seems to me that it would be a good idea to have a separate oil supply to a turbo. I can see some benefits (don't know enough about motors to see drawbacks...)
If there is an oil leak, then engine won't blow due to oil starvation.
Could have oil in a seperate 2-3 quart reservoir with a built in cooler to feed it.
Oil changes would be done more often on the seperate reservoir, while motor oil can be changed at regular intervals.
Just a thought.
Old Feb 12, 2010 | 05:01 AM
MADjdm's Avatar
They do exist - don't think any are in the market yet though.
Old Feb 12, 2010 | 08:18 AM
deathsled's Avatar
check out Aerochargers, kinda pricey and I believe they only have 2 models. They are variable vane turbos that also require no external oil or coolant lines.
Old Feb 12, 2010 | 08:29 AM
crazy stuff out there
thanks everyone
