Motor mount wont fit!
I installed a pro street full race turbo kit with a borgwarner s200sxe turbo, i removed the motor mount to fit the damn manifold and turbo, now i can't get it back in, i tried jacking up the motor an
I can fit this piece no problem but getting the other to fall inline with the screw just aint happenning, i can also bolt ob the top piece but fitting the bottom piece aint happening.
d all. I looked at after market mounts i dont know if they're some smaller ones
im planning on grinding down the motor mounts enough to make it fit, i dont know if its a good idea.
what yall think???
what yall think???
Do the engine mount brackets attach to the block without contacting the turbo? If so, then it should fit unless the turbo is contacting the frame there. If the turbo is contacting when you jack it up high enough, then you may need to get creative with the install.
i am gonna try a few more time, dont really want to grind down the mount, and yes the turbo is getting in the way of the top mount,
Was this turbo kit built around a specific aftermarket mount? If it's specifically designed for an S2K, it should clear the OEM mounts (I would hope). I wouldn't start shaving material off of the factory piece.
I had to switch to Hasport motor mounts when I installed my Full-Race pro street kit with a GTX3576 1.06 housing. Stock mount would not fit....Hasport mount provided enough clearance.
what yall think???
what yall think???
