Test pipe with supercharger?
Old Sep 17, 2006 | 10:03 AM
EK9MAX's Avatar
Default Test pipe with supercharger?
Hey. Are you supercharger guys using test pipes???
I hear it gets really stinky and black smoke a lot if you use one with your supercharger??
any input?
Old Sep 17, 2006 | 12:29 PM
Dsgs2k3's Avatar
i am running one. i like it
Old Sep 17, 2006 | 12:36 PM
XclusiveAutosports's Avatar
It shouldn't be any different then running a testpipe on a NA s2k. It will still have that catless smell, and when you floor it you will see some black smoke. If that's not for you, then keep your cat in.
Old Sep 17, 2006 | 08:22 PM
evf2000's Avatar
Yeah but it makes wicked cool flames!!!
Old Sep 17, 2006 | 08:49 PM
BlownAP's Avatar
if you are running the vortech with the Black box and you add a test pipe, it will make you run very very lean.......
if your tuned it shouldnt be any differant than on an NA set-up
Old Sep 17, 2006 | 09:19 PM
moonliver's Avatar
Id like for someone to describe technically why the back pressure of the cat causes more fuel to be dumped in. I cant derive an accurate description of the phonominon.
Old Sep 17, 2006 | 09:55 PM
Enthralled's Avatar
hey thats my setup....I like the extra kick the test pipe gives...
Old Sep 17, 2006 | 10:46 PM
Sideways's Avatar
It doesn't. It's the other way around. Less back pressure causes it to run lean.
What is "phonominon?"
Old Sep 18, 2006 | 03:20 AM
jbotstein1's Avatar
Phonominon: Noun. A mixture between a record player and a very nice cut of beef. Pronounced Fo no min yawn
Old Sep 18, 2006 | 06:33 AM
CrazyCracker82's Avatar
that's wierd i'm just on a stock vortech with no tune and i'm running rich and i have test pipe
i guess it's my 00 ecu that's keeping me running rich
