Thinking of getting a Garrett GTW3684
thanks for your review op. staying on topic on affordability, i think i have you beat LOL. i have an even cheaper garrett t3 60 trim journal bearing -58mm- turbo. It's rated at 500hp at the crank, which i've exceeded and running at 515whp. Boost comes on descent at around 5000rpm. It has a fat power band and is very responsive for a jb turbo. I'm guessing prob because of its small frame. Very cheap, very reliable turbo for those seeking to stay at 500 or less whp. might upgrade to the garrett 60-1 at some point to make 600whp.
here's my dyno graph at 499whp and 367wtq:
Just a theory though, I think on pump gas an old school 58mm Garrett would struggle with 500whp on Dynojet?
So just an update
After 1 year of my turbo stuff lying around the shop I found the time to do the install and tuning it. All of the custom fabrication was done at my shop and tune on the ECU by me. So here are the basics of my setup:
Garrett GTW3684 journal bearing turbo
AEM Series 2 ECU
AEM fuel rail + reg
AEM 340lph fuel pump
AEM water/meth injection (50/50 on smallest jet)
ID1050X injectors
TiAL BOV and WG
ACT HD clutch
F20C bone stock except for AP2 retainers
Heres my dyno on low boost (11 psi) and high boost (16-17 psi) both on pump gas with the water/meth turned on only at high boost
Overall, I’d say the turbo isn’t spectacular nor garbage. It performed just the way I’d expect it to be and made the power expected (could have pushed maybe up to 530-540+ at same 16-17 psi). It spools a bit late (full boost comes on at 6,000-6,500) so its not something I’d call a responsive turbo on our platform. Given the price though, it’s a good option to Precisions 6262JB series and to BW S300s if youre targeting the same numbers as I did on pump gas
AEM Series 2 ECU
AEM fuel rail + reg
ID1050X injectors
TiAL BOV and WG
ACT HD clutch
On E85 3476 can go 550 or thereabouts but Im not running nor planning to go to E85 anytime soon
Correct, 550whp on E85. However, you're only making 500whp with the 3684 and I bet the 3476 would be damn close to 500whp with the 50/50 water meth you're using. Let's just say the 3476 only does 475whp with the water/meth, you'd still gain a ton of area under the curve and have a much faster car.
For track / circuit purposes this would be a stupid purchase obviously, but thats not what I do. And I also think that a 3476 would walk over this on short spurts especially when the 3684 is in the wrong gear at the wrong rpm (which sucks really).
Given my relatively traction limited setup, the less brutal punch of the quite laggy turbo is more favorable actually. But of course we all know given the right parts and budget, these cars can be setup to hook up nicey even with the punch the smaller turbos produce
OP how are you liking this turbo after having it on the car for a while? Have you upped the boost at all? T04S compressor cover correct? I am eyeing the same turbo same Tial style .82 vband in/out turbine housing - looking for an affordable option that will make north of 600 whp comfortably.
No sorry still on 17 peak psi only. Tried to do a bit of 20 psi pulls on the street when I got bored but brought it down again lol
Yes correct S housing cover
Honestly, I think you would be better off with the 3884 if you want to do 600 and still have a bit more elbow room in the future. By the look of things this will do 650-700ish on E85 but might be a bit pushing it already
I have currently ordered a dual pump hanger and ID2000s plus flex fuel sensor so I just might see where this turbo taps out before replacing it. That is if I find the time to install parts soon
People got money. The GTW is still a $1000+ turbo. The GTX series are near $2000. You can also consider t3 60 trim and 60-1 jb garrett turbos for $750. For those on a budget. Still make +/- 500whp. Obviously, you pay to play. The more you pay the better the turbo characteristics will be. But for the average joe, best bang for the buck, can still hit a solid 500whp with <$1k turbos and still have reliability of a garrett. I'd love to run another s2k with similar hp with an expensive gtx turbo and try to see any performance differences.
