Throttle Body
Old Aug 22, 2006 | 10:45 AM
sazukabluz's Avatar
Default Throttle Body
Hello gang just wondering which throttle body would be best for my setup and
bigger power gains.What mm should I go with as well as what company
I should go along with.I'm currently running a stock ctsc w/aftercooler with plans
of upgrading soon.
Thanks for all and any helpful info.
Old Aug 22, 2006 | 11:19 AM
j_c_a's Avatar
I'm not really sure a bigger throttle body is going to help you much unless you get up in the 10lb + range for boost. Having said that, I'm running a 70 mm BDL TB. Not sure what it contributes in terms of hp, other than acting as a compliment to a high-boost setup. Remember that in order for a bigger TB to make any difference you'll need to port-match your intake manifold to it also.
Re: the BDL TB specifically, the spring is super stiff. It takes a little while to develop the right touch to get the car moving w/o stalling. At the same time, that works great for me b/c anytime someone asks to drive the car, i tell 'em only if they don't stall it the first time
Old Aug 22, 2006 | 12:24 PM
CaptKirk's Avatar
of upgrading soon.
Sup man
Check out the Science of Speed TB. Kevin has it and really likes it... hit him up for more info.
Old Aug 22, 2006 | 01:33 PM
John_Z's Avatar
Pro Flow will bore out your stock one to I believe 68mm and it will match up with your stock manifold.
Old Aug 22, 2006 | 02:30 PM
CaptKirk's Avatar
If I'm not mistaken, Science of Speed does the same thing...
Old Aug 23, 2006 | 04:25 AM
NO S8NT's Avatar
of upgrading soon.
Craig hit me up...I got a deal for you
Old Aug 23, 2006 | 08:07 PM
s4000k racing's Avatar
i have a 74 mm by str
Old Aug 23, 2006 | 09:22 PM
S2KPANG's Avatar
Has anyone had tried them before? I'm thinking about send mine off there to get it bored.
Old Aug 24, 2006 | 04:37 AM
NO S8NT's Avatar
I'm currently running the SOS on my car now and love it.
Old Aug 24, 2006 | 05:54 AM
MugenRioS2k's Avatar
Did you see any gains or was just throttle response improved.
King offers the same type of service but I am not sure if they bore it al the way to the Throttle plate. SOS must taper the TB all the way to the TB/plenum interface since they replace the throttle plate.
