Tubular vs. log-style turbo manifold
Old Jan 18, 2007 | 07:14 PM
  #21
timg's Avatar
Let's look at it like this. Which looks as if it flows well? Which does not?
This is NOT a comparison with Inline Pro's manifold or with the Lovefab Mini-me, but with all of the weldbend log manifolds instead.
Typical Log Manifold
Tubular Manifold
Tim
Old Jan 19, 2007 | 02:14 AM
  #22
ya@inlinepro's Avatar
Well put Timg.
Again, we have dyno'd more than JUST our cars and brian has tuned more than just a few hondas, so we've seen many different turbo setups vs many different engines.
There are many comparisons from a log vs tubular but our manifold was not used. Even though our manifold looks like a "typical log" there was a design to it that allows it to work so as well as it does.
Old Jan 19, 2007 | 03:51 AM
  #23
geists2k's Avatar
I have yet to see a crack in my InlinePRO manifold.
Old Jan 19, 2007 | 05:04 AM
  #24
AROD's Avatar
until the day comes when someone on the same day switches manifolds on their own car from log to tubular, and makes more power, i won't believe the hype.
2qyk4u, what kind of manifold are you running now??? If you are running a inline pro manifold i highly doubt full race will make 60 more hp than that with same boost levels and all
Old Jan 19, 2007 | 05:15 AM
  #25
inlinepro1's Avatar
2QYK4U, just look at numbers at the same boost levels as you i cranked out 375whp. Exact same set up except the turbo. The turbo size makes a big difference
Old Jan 19, 2007 | 05:29 AM
  #26
2QYK4U's Avatar
I have an inlinePRO turbo manifold. Full-Race knows this, and will guarantee me that their turbo manifold will make at least 60rwhp. Here is a direct quote from them:
"We will guarantee those gains only if you used an approved tuner, do a baseline test, change only the manifold downpipe and wastegate, and retune on the same dyno within a reasonable amount of time. This may seem like a lot to ask but we are very confident in our products and we have done a lot of back to back testing and this is the most reliable method. As long as you follow this guideline we will guarantee a 60 -70 hp gain."
Old Jan 19, 2007 | 05:31 AM
  #27
2QYK4U's Avatar
I understand that a larger turbo is capable of making more peak power, but it also takes longer to spool. I specifically chose a GT30R over a GT35R because I plan to road race my car and the GT30R spools quicker.
Old Jan 19, 2007 | 05:48 AM
  #28
inlinepro1's Avatar
around what RPM are you making full boost at?
Old Jan 19, 2007 | 06:15 AM
  #29
GrandMasterKhan's Avatar
as an example. LoveFab GT1 the vtec is set @ 4500 but with inlinepro Vtec is @ 6500.
wouldnt this lead to a much meatier midrange powerband for the lovefab even if the peak HP is the same?
(i know there is more to it than that but just using this as a rough example)
Old Jan 19, 2007 | 06:29 AM
  #30
AROD's Avatar
with my inline pro turbo i have vtec set at 5500, also, when your boosting and making power, if you can feel vtec over boost, then somethings wrong, i havn't felt vtec since my car was stock.
