Turbo coolant lines - S2KI Honda S2000 Forums
Notices
Turbo coolant lines
Old 01-21-2019, 04:39 PM
F1TwoThousand's Avatar
Default Turbo coolant lines
Deleting the oem oil cooler donut and routing those coolant lines to turbo but which is the return and high pressure line?
F1TwoThousand is online now
Old 01-21-2019, 06:24 PM
I did this as well. The line coming out of block by oil pressure sender unit is the Feed line It should go on the bottom plug of the EFR center housing. the line infront of the timing cover is the Return line and should go on the top plug of the EFR center housing. Ideally they should also be cross-directional across the EFR housing as well (IE: Enter into bottom right of housing and Exit out of the Top left of housing).
ninetysixyenko is offline
The Following User Says Thank You to ninetysixyenko For This Useful Post:
F1TwoThousand (01-21-2019)
Old 01-21-2019, 11:37 PM
Good thing i asked, i thought the black line was the feed line. Thanks for the help
methduck
01-28-2014 08:52 PM
Funtimefrankie
11-24-2013 11:47 AM
S2Krazee
09-26-2008 02:54 PM
sIIooo
02-23-2008 09:30 PM
skibum
10-21-2007 05:40 PM
Quick Reply: Turbo coolant lines
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
