Turbo Mounting
Well I am about to get started on my new build. There is just one main problem that I can't stop thinking about. My turbo is currently located in a position that is NOT FUN TO
1. Access
2. Remove
3. Adjust
I would like to get a manifold that is easy to do all of the above it just seems that this would make life easier down the road. I was looking at Lovefabs sidewinder, which we all know places the turbo right in front of the motor and from what I can see it looks pretty accessible. Below is a link to give you an "IDEA" of what I
1. Access
2. Remove
3. Adjust
Originally Posted by timg,Aug 29 2006, 07:53 PM
One other thing. I highly recommend a V band exit on the turbine housing and no water cooling if you want something easy to remove and install.
Tim
Tim
Originally Posted by PRS2K,Aug 30 2006, 03:51 AM
Tim which manifold is it that you are using. I see it pictured to the Left. Is that the Mini
Yeah, it was made locally by a guy who goes by GJ. Pang is currently making the closest manifold design to mine. I actually had him weld up some cracks in mine. He should be selling them through P Fabrications. He's on here, S2KCA, and High Altitude Imports. My manifold, plus a non watercooled turbo, plus V bands would be incredibly easy to swap in and out. The watercooling does make things much harder on mine. IMO, the only parts of the entire exhaust system that shouldn't be v-banded are the turbine inlet flange and the cylinder head flange.
Tim
Tim
