Turbo Oil Return Line Tap Location (Post yours)
I have a 5758 ball bearing with a MASE kit and I have read many many posts about people burning oil on acceleration and/or deceleration. The common fix is to use a .03" oil feed line restrictor in addition to the factory .035" inside the cartridge due to the high oil pressure on the S2000. After speaking with a PTE rep today, the 5758 has a 25mm oil return opening. The MASE kit shipped with a -10an line and the cartridge flange it was shipped with had a 13mm opening. This creates a similar condition to crank pressure or oil backup into the line which causes those little puffs of smoke.
I am going with a -12 line and fitting to go with the larger flange you can order direct from PTE. The question is now that I am faced with putting a larger fitting on the motor for return, what is the best location? I have read some guys swear by the girdle and others say pan is fine. For those of us who do not have the engine out of the car, the girdle seems impossible. Additionally, some people choose the timing cover, but I have seen some diagrams showing that is where the F20 primarily pushing crank pressure up through so it seems like that would not be a good place. I want to open the discussion to opinions and facts about good locations as well people to post theirs. Andy https://lh3.googleusercontent.com/-_...o/IMG_5638.JPGhttps://lh4.googleusercontent.com/SX...4=w503-h671-no |
1 Attachment(s)
The girdle is where I placed the oil return, as it's impossible to use the timing cover for return with the FullRace Prostreet (ramhorn) manifold. It's possible to drill the girdle with the engine in the car. You just have to use a drill similar to this:
http://www.westerntool.com/makita-3-...gle-drill.html |
on my full race ramhorn i had the girdle tapped, on my foward facing one i use the timing chain cover for the return
Put that sucker straight into the factory oil drain
Originally Posted by Prokaw875
(Post 22907177)
I'm running a -10 fitting as high as I could get it in the pan. Similar to the OP. I've never had any issues with my pfab top mount log or my current sidewinder.
Originally Posted by beaudin223
(Post 22907201)
Originally Posted by LilJoe
(Post 22907215)
Originally Posted by beaudin223' timestamp='1386185938' post='22907201
[quote name='Prokaw875' timestamp='1386184804' post='22907177']
Put that sucker straight into the factory oil drain [/quote] x2....mine is on the stop left side of the oil pan by the ac pump |
Timing cover, girdle or top of the pan by the AC compressor. Pick one and use it. I myself am using the timing cover and have had zero issues in the last 10k with my JB 6262.
