Upgrading fuel system ideas for NOVI 1200/1500
thanks for the input, however I have and will be using the SOS piece as it makes for a clean, reverse-able install if needed
interesting as the will eliminate the need of a second set of injectors, rail, injector driver, etc. The biggest thing for me with these is the have to idle, light cruise, and provide part throttle as the 1000cc injectors with both 93 and e85. Thanks for your input I will be looking into them
I am leaning towards the ID1700s at this point, I will update the possible cost later today. I'm thinking if I get them and are in happy with them they can still be my secondary set of injectors
Im pretty sure ID have had a big revamp of their injector line up. I recently fitted the ID1050x injectors and one of the plus points compared to the old injectors are improved low pulse width performance.
As for O2 Feedback that is completely down to whoever maps it and how close they get the map to being perfect before they hand it back over to you. I know most people tend to run the ability for the ECU to add or minus 10% of fuel. You can chose whether you want the ECU to change the mixture whilst in boost but it depends on you having a good Wideband and ensuring you treat it as a serviceable item that needs changing occasionally. Mine is referenced whilst in boost and lasted about 2 years before its response started to tail off so i replaced it.
I have the id1700's they will not idle like stock (high idle and a little rich) but the drivability is very good and they flow very well. I would recommend id 1300's, a 450 pump, and a external fuel pressure regulator for your 500 + goal.
Awesome thank you! I wonder if they are enough for 560-600whp with an SC
