Vortech Dyno Plot
Old Jul 13, 2007 | 07:19 PM
batikan's Avatar
i don't understand how some people get this much TQ. When I was at 11.5psi with my vortech, I made 355whp and only 209wtq
Old Jul 13, 2007 | 09:10 PM
WLAURENT's Avatar
Originally Posted by versionJDM,Jul 12 2007, 04:35 PM
12:1 is plenty rich for VTSC setup. once you go back to stock id get retuned and and lean it out a bit.
12:1 is rich? With the summer temps I would prefer to be in the low to mid 11 range. I would be afraid to boost if my car was hitting 14's anywhere under the RPM range.
Old Jul 14, 2007 | 07:15 AM
joes sled 2000's Avatar
I agree here. Looking at my ap1 dyno sheet im as lean as id ever want to be. After installing an vortech kit in an ap2(with the 5th injector)and dynoing it i was pleasantly surprised to see how rich it ran. Ive been waiting for this new aem piggyback system but now i have some different ideas.
Batikan , ive installed three vortech kits now and they all made very simular numbers with my ap1 making the most .The ap2 i just finished made 200 lbs wtq. Perhaps you were not getting the advertised boost level??
Old Jul 14, 2007 | 07:31 AM
ATOice's Avatar
good numbers, but I figured another 15 lbs at least of torque.
Old Jul 14, 2007 | 07:53 AM
ChefJ's Avatar
Exactly... Unless I see a dyno I won't believe it. My 10psi setting on my turbo hits 305hp and only 205 torque.
Old Jul 14, 2007 | 07:54 AM
ChefJ's Avatar
Although my torque is at the peak around 4500rpms and maintains the line all the way through to redline, which is what really matters.
Old Jul 14, 2007 | 08:31 AM
WLAURENT's Avatar
I am running an eManage Ultimate and driving a 5th injector off of the sub/inj map. Was planning to use the AEM F/IC, but when they started having some issues with the timing control I decided to try out an Ultimate.
With the AEM F/IC I would still need to use a seperate box to control my 5th injector and could not use AFR feedback to tune the maps. Plus I have found that the IAT correction map (timing and fuel) on the Ultimate is a big help in dealing with the big temp swings we have here in Arizona - the AEM F/IC does not have an IAT correction option.
Old Jul 14, 2007 | 03:15 PM
So youre saying the dyno sheet i provided is bullcrap??????
Old Jul 14, 2007 | 10:01 PM
WLAURENT's Avatar
You have to consider the relationship between TQ and HP.
TQ = HP * 5252 / RPM
If you have 305 peak HP at 8000 rpm - you are only getting 200 ft*lbs of TQ
If you make the same HP at 6000 rom - you are making 266 ft*lbs of TQ
That being said - you could have a car that hits 400 HP and only making 233 ft*lbs of TQ. Really depends on where your HP is.
Old Jul 14, 2007 | 10:05 PM
Enthralled's Avatar
I'm running stock boost
btw it was hot outside the day i had the dyno done...well into the 90's
