Vortech freshen up
So after 13 years and 70k trouble free miles my old S trim Vortech is starting to show some age . It is starting to leak oil out of the seals to the point of covering the back of the blower and mounting brackets with oil . I am sending it back to Vortech for a freshen up or as they call it a minor rebuild . I am however thinking that perhaps i should upgrade it to the Si trim . I am wondering if anyone has done this and if it is actually worth it . I do realize that it will make more boost for a given pulley size but that isn't really my desire . My thinking is the Si trim is more efficient thus a cooler air charge . I would keep the boost at 13-14 psi revving it out to 9k as i have always done . Supercharger gurus please comment . Thanks !
Si is much more efficient and worth the money. I went with the V7-YSi and it rocks.
Are Vortech units better than Paxton? I think they're similar brand but I keep hearing about new trims from Vortech yet with Paxton it seems like they've stuck with Novi1220, 1200, 1500, 2000 units for some time now.
No , Paxton is to my knowledge the parent company of Vortech . They are all very similar . Paxton uses numbers instead of letters for there various trim levels .
Originally Posted by Sideways
(Post 24576202)
The Si is very capable. I got it and upgraded to higher speed bearings. At about 22psi and 10:1 compression on 93 pump and meth I made 470whp and 520whp on E85.
Was this on a stock engine ? Never mind , i just noticed you said 10.1 comp . I'm still on the oem engine . This is why i'm inquiring .
I'm using darton dry sleeves and cp pistons. People have gotten similar results on stock blocks. The only reason I went this route is from hurting the OEM setup. My aftercooler pump failed, and I failed to notice my AITs climbing resulting in enough detonation to require a rebuild.
Originally Posted by bruthaboost
(Post 24576530)
Originally Posted by EOE
(Post 24576634)
Woah, that sucks... the ECU compensation tables didn't pull enough ignition timing and add fuel to save the motor?
