Want 500 hp and a smooth engaging clutch? We have your solution here!
The friction disc that comes with your sport clutch is inferior to OEM, its way too grabby and wears quickly as I mentioned, but its a good PP with an OEM disc as a combo, such as the common Act PP with our OEM disc many of us run (that PP you can buy separate). After about 15k miles I replaced the sport clutch disc with an oem friction disc, had smoother engagement and lost no holding capacity. If you offered just the PP, you would probably sell more of them. Your new higher holding capacity clutch may prove to be a similar situation in the long term, just have to see how it pans out in the real world. This one will be competing directly with the common go to ACT PP with OEM disc combo which holds a reported 380trq+
davidc1 (12-24-2016)
That's proven bogus.
For what it's worth, I have tried the OEM disk with an aftermarket PP (Spec stage 2). While it drove well, it couldn't hold up to a decent sized turbo. Once it hit full boost in higher gears, the clutch smokes itself. This same setup with the proper disk easily held 363 ft-lbf on my old turbo setup. At the time, the only way I could guarantee that the new clutch would be street able, reasonably quiet, and would hold the power was to go with a SOS twin carbon clutch. This seems like an interesting alternative.
Tim
Tim
Tim
Tim
buy a new clutch, before you install it call a custom clutch company and make a few extra disks. If you in NY or want to ship a disk to them, I highly recommend Falcon Clutch. They make prototypes for OEM manufacturers. Price is super competitive, but wait times can be up to a few weeks.
Former Sponsor
While I respect your point of view, I think you're misinformed. The disc you're referring to used in our Sport clutch (not the one we're introducing in this post) which you refer to as "inferior to OEM" is incorrect. The disc is literally OEM and identical to the high quality factory part. You'll note the "Honda" logo on the disc hub if you look closely. If you replaced the disc with a disc from Honda, you replaced one part with an identical part. I can not explain why one would feel different from another - it likely could be a input shaft lubrication problem between the first that was installed and the second.
The other dissatisfying part was not being able to purchase your clutch separate from the PP/friction disc. At the time, the option was going with your new sport clutch or risking going with the Act PP/OEM disc with "crank walk" still in the forefront of our minds, So I didn't want to risk running the old ACT PP and opted for yours. I seem to recall on your website, or may have been speaking with you overt the phone (its been a wile) stating the friction disc were modified OEM? What was modified? Did you offer a different friction disc with your sport clutch when it first came out 7-8 some years ago when I purchased? And was it eventually revised to pure OEM?
2 out of 2 back to back, with then switching to OEM supplied Honda disc shaped my experience, and so I will continue to use your PP (which I think is great) when its time for a new clutch, but it will get another OEM disc. Im on the 3rd disc with the same/current SOS PP with a little over 100k on it. The Honda supplied OEM disc has been on for 80k+ of those miles and still good. I might consider a new Sport PP if you offered one when I get closer to 200k, but im not willing to try another one of the disc you pair with it, so that might put me into another option all together when that time comes.
Here is to the new Sport 400, look forward to the reviews
Former Sponsor
I think highly of your products, and know you Chris have been a player since the start, so I have always been a strong advocate for your company. But sharing my knowledge and experiences to the club ive been apart of for nearly a decade is what its about for me if it helps steer people in the right direction, otherwise what good am I. Ive run 2 of your sport clutches so 2 different sport clutch disc with your PP and 2 OEM disc on the last most current PP. Both supplied sport disc performed the same way, same pedal feel, so nothing related to lubrication, but they were grabby and chattered when going in reverse, and a rather surprising rapid wear rate. I never had any hence of slipping however, so they held fine. But the disc smelled regularly from normal driving around town with slightest of inclines where a little more slip modulation was needed in normal day to day use. Those disc are long gone so I couldn't pull one out to verify what you claim today, but I seem to recall the design and color of the friction material different then the OEM disc I had when comparing them back then after inspecting the first disc in dissatisfaction.
Former Sponsor
Tim
Tim
Thank you for taking the time to post the review, we really appreciate it! I'm really not sure what to say about this - the disc that you buy from Honda is definitely the same as the disc we supply in the kit (what we call our Sport 325 now). We've installed a large number of these in house - and they are definitely very smooth to engage, just like factory. In fact, we've had feedback that people think it's too smooth for a clutch that's labeled "sport". If you'd like - please drop me an e-mail to info@ScienceofSpeed.com so we can further the discussion to see if we can glean anything from your experience. Thank you!
I cant tell you where the discrepancy comes from either, but know that my experience with the sport clutch is not exclusive, it is shared with some others on this website that have reported identical characteristics - and they may/may not choose to chime in if they like. Not sure what else there is to say about it, it was what it was. I don't want to potentially detract from your new current offering in clutches here, so that's all I will say on the matter. Again the new Sport 400 appears to fill a niche many are seeking, so again good on you for offering the new option.
