What bolts?
Hey guys going to be starting a build thread in the next few weeks but before I do that I need to finalize all my parts to avoid unnecessary downtime.
I am after the correct bolts for the fbm sidewinder mated with the precision 6266b (0.81a/r) it's the 4bolt pattern.
I would much prefer to use arp but I am up for suggestions. Keeping in mind that I am located in australia and we don't have any of the stores I named in many threads I see.
I Also need to buy some heat sleeves or heat shielding for some wiring located near the manifold. Also should i wrap the silicone hoses for the wastegate etc etc or do you guys recommend any other material to use on the wastegate which is better with heat? Any recommendations?
Also want to know is the Mac solenoid compatible with the haltec platinum 1000? If so any wiring diagrams available?
I'm sure there's a couple more things I need to work out before I start the build.
Thanks guys!
Manny.
Thanks guys!
Manny.
Hey buddy, you need 3/8-16 bolts for the flange
http://www.full-race.com/store/turbo...dware-kit.html
(you can get these from a hardware store if you'd prefer)
I will check them out.. I am not really fond of tapping threads had my fair share of disasters
