Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Forced Induction
Reload this Page >
What size are stock fuel pump fittings
Old 09-11-2012, 08:41 AM
Default What size are stock fuel pump fittings
Hey, I need some help im trying to convert my stock lines to braided lines, and can't seem to find what fittings to use on the stock fuel pump housing. The white push fittings on the top of the pump are what I am talking about. Im tring to figure out what size to use they dont come in metric, they come in 5/16 and 3/8. I dont know if they will work but I think that they should. Anybody done this and remember what size they used or what they used?
Im talking about the fitting on the end of #21 and #22
I want to use something like this but dont know what size I need.
onlystunna is offline
Old 09-11-2012, 10:33 AM
I used the following fittings:
Russell -6 male to 3/8" female #640850
Russell -6 AN male to 3/8" male #640940
The plastic insert for #640940 was flimsy, so I recommend you buy the Honda piece and install that instead.
99SH is offline
Old 09-11-2012, 12:46 PM
could u post a write up of your conversion ?
I think there is a lack of info on fuel system upgrades In this forum. Well at least past the usual in tank pump install and injector questions
A nice how to replace your fuel lines and what connectors to use would be useful
indebt&lovinit is offline
Old 09-11-2012, 01:45 PM
The mods I performed was to add a fuel surge tank, as opposed to re-plumbing the fuel lines going to the motor.
For what you're trying to do sounds pretty straight forward once you identify the fittings required on either end.
99SH is offline
Old 09-11-2012, 02:14 PM
I want to run this : http://www.034motorsport.com/fuel-in...k-p-21527.html
And if I can just plumb it up with the fittings above on the end of the OEM line that would be sweet
Old 09-11-2012, 07:30 PM
ok Ill try to start a writeup Ill complete it tomorrow.
I skipped the part where I installed my injectors and installed my aeromotive 340lp pump there's info on how to do that on this site. My tips are number one is if your using that stock hanger take that dampening black sock that fits around the pump and chuck it, it makes the pump to big to fit in the hanger. The Id2000 injectors are a tight fit in the inline pro rail so lube up the orings on the injectors and the holes in the fuel rail and push them in its gonna take some force.
Ok now Im gonna use the stock evap line as my return line to save some money. I'll see if I can get it to work if not I'll do something else. but onto the feed I Brought the fitting that 99SH recommended I wanted black.
Here it is installed, it has orings inside so lube it up I like spraying my stuff with windex it lubes it and dries away like it was never there.
$15.99
I will use -6 feed to the Bosch 044 and a -8 outlet will pst those pics tomorrow when I install it.
the fuel rail will have a -8 feed and a -6 return
8 an Straight Cut O-Ring To -6 an Male Flare PRE-77086 Return fitting $8.07
8 an Straight Cut O-Ring To -8 an Male PRE-77088BLK Feed Fitting $9.02
Got my stuff from these guys there local and match there ebay prices in store
http://myworld.ebay.com/getfast1?_trksid=p2047675.l2559
I pulled out my evap system and canister and will mount the 044 there will post tomorrow when I finish
Old 09-11-2012, 07:53 PM
How hard was the removal of the evap ?
Also thanks for the write up. It's always nice to have pics of a future project
Side thought, I assume your are going to run E-85 with the size of those injectors. Now my ? Is E-85 won't screw with the OEM plastic fuel pump housing
Old 09-11-2012, 08:30 PM
Nice a fuel write up, i planned on doing a write up soon. Just gathering fuel things for fbm dual pump setup.
Sent from my PC36100 using Tapatalk 2
miguel329 is offline
Old 09-14-2012, 07:16 PM
Any updates?
Old 04-08-2019, 04:47 PM
Excuse the thread revival but does anyone know the oem hanger feed/return nozzle size? Some say 3/8 others 5/16. Can anyone confirm
thanks
2rbolag is offline
Quick Reply: What size are stock fuel pump fittings
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
