Whipple Supercharger S2000 Kit
https://cimg1.ibsrv.net/gimg/www.s2k...166a2f0ed.jpeg https://cimg1.ibsrv.net/gimg/www.s2k...05d0513e3.jpeg https://cimg2.ibsrv.net/gimg/www.s2k...486080759.jpeg Boost Engineering & Fab is developing and releasing a supercharger kit utilizing a Whipple 1.6L. This will me made from high quality high strength billet aluminum parts and an integrated air-to-water intercooler. The setup is a bolt on kit to make it simple to install. A positive displacement supercharger will provide instant torque and better driving feel and response than anything else on the market. You can see more information and updates on their Facebook page and I will try to add it here as it comes up. |
That looks neat. Thanks for sharing.
Will be interesting to see how this preforms on a high revving 4 banger compared to the old SOT kit which was limited to about 350whp and quite high IAT.
Two questions:
1) What is the design of the intercooler? It doesn't look that large in the picture. 2) Is 1.5L a little large for a 2L or 2.15L engine with 11+:1 compression ratio, at least on pump gas? I think Sprintex has both a 1L and 1.5L for the FT86. If this is reliable, it would be the best-forced induction option for S2000s primarily used on the street, autocrosses, or road racing circuits. |
Originally Posted by DavidNJ
(Post 24542910)
I assume that part is still on paper. |
I hope this does well. More options are always welcome however this teaser pic doesn't inspire confidence. For instance, look at the thickness of the flange the blower is bolted to. That flange looks to be holding the blower on, so it's load bearing, and it appears no thicker than 1/8". I hope this is just a positioning concept test.
Originally Posted by bruthaboost
(Post 24542925)
Please keep in mind you are correct in the prototype of this one. Yes the production model will be all quality and strong billet components. To go along with that flange, there is a steel brace support directly under that location to support the weight of the supercharger.
Originally Posted by s2000Junky
(Post 24542913)
So small in fact its like its invisible :p
I assume that part is still on paper. ROD |
Originally Posted by rrounds
(Post 24542956)
I think its built into the intake, Looks like a hole for a fitting on the front of it? Air to water?
ROD Running a multi port water/meth injection system would probably yield some seriously higher safety and power benefits for this kind of system configuration in particular. If the kit doesn't come with port provisions for this in each runner, it would be the first thing id do before instillation. |
