whos running the sos flex fuel kit
#31
So when your fuel temp goes over certain temp. what do you do? pull over the road and let it cool down? what temp do you need to be under? which fueld temp gage do you recommend?
#32
I always thought it wasn't so much the fuel heating up but the pump generating the heat O_o meaning a overworked pump will generate more heat, as a properly sized pump/larger would not
#33
Ohh i understand. well i have seen many peepz run e85 with FBM340 with a gtx3076 on pfab elt 550whp no problem so i should be good but i dont know about the Original Poster.
#34
I find it hard to bite on the idea that the MFG. Engineers would band aid a overworked fuel pump by adding a temp sensor. Just my .02
Not saying anything here is definitive or I am right over another, really just speculation.
#35
#36
The "temp sensor" is part of the flex fuel sensor and is only there because it's needed to calculate the correct ethanol content.
I guess it can be useful to log and have some compensation for it as well but I doubt OEM cars use it.
Check this link for more information how the flex fuel sensor works Clemson Vehicular Electronics Laboratory: Flex Fuel Sensors
#37
#38
Ahh so Flanders is saying it works in conjunction with sensor to provide a accurate percentage reading.
Maybe because it's oxygenated, heat disperses it or enlarges the air molecules effecting ethanol content.....I'll read the article now lol enough guessing.
My main point was that 99% of these sensors are OEM/MFG and they have strict budgets, guidelines, "creature comforts" QA/QC and has to perform in a lot of environments so my thinking is if it's there 1: oem cars deffly use it 2: it is functional and 3: adheres to one of the listed guidelines or something I left out.
The consensus or conclusion of a overworked fuel pumps an e85... To Mee is the "modders" or performance enthusiast byproduct of finding a deficiency in a set of parts on a car never engineered to be boosted or "flex fueled" in the first place. My first post "thought" could be argued this same way tho. (tuner error etc)... thats why Flanders post "makes sense" to me n sounds more planted with a lot of encompassing forethought, and it's backed by a laboratory article from the looks of the link.
#39
Might not be correct but after seeing fuel corrections for IATs, ECTs, ignition tip in trimming it doesn't seem that far fetched but as we read earlier it sounds like it's just a way to get an accurate ethanol content percentage.
nMeOnE
07-11-2017 03:20 AM
