S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   Wideband ELD Resistor 07 AP2 (https://www.s2ki.com/forums/s2000-forced-induction-142/wideband-eld-resistor-07-ap2-1107064/)
JayRSXS Nov 30, 2014 06:38 AM
Anyone know which resistors on an 07 ap2 do you cut on the ecu to utilize the the wideband eld option. Can't find a direct answer...
SLWS2K Nov 30, 2014 06:56 AM
https://www.s2ki.com/s2000/topic/109...band-question/
JayRSXS Nov 30, 2014 10:40 AM
Still not reading the same or passed 12 doing all that
SLWS2K Dec 1, 2014 06:32 PM
I ended up using the egrl input per my tuner (vitviper) for better air fuel readings at the pcm. Can't remember why but something to do with the input voltage readings are better on the egrl vs the eld input. Don't quote me on that though :)
JayRSXS Dec 16, 2014 05:32 PM
It doesn't have the egrl input on mine
VitViper Dec 16, 2014 08:54 PM
^ Bingo.
Almost none of the AP2 ecu's have it -- Hondata can add the EGRL circuitry for you, and boost control (PWM circuit) for you if you send them the ECU.
The ELD input sucks because of the resistor (resistors? or even other circuitry possibly) preventing voltage readings below 1v (basically it always reads at least 1v no matter what). So with most widebands that amounts to not seeing below 12 afr or so. I'm not sure what circuitry needs to be modified to resolve this, or if it's even possible to do so on this ECU (it was on the old PRB RSX ECU's).
© 2026 MH Sub I, LLC dba Internet Brands
