S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Interiors (https://www.s2ki.com/forums/s2000-interiors-252/)
-   -   CR Trunk Trim (https://www.s2ki.com/forums/s2000-interiors-252/cr-trunk-trim-836683/)
OldDog Dec 23, 2010 10:24 AM
CR Trunk Trim
I'm removing my spare tire and would like to get rid of the bulge in the trunk. I assume the CR does not have a spare tire, does the CR have a different trunk trim? Flat instead of rounded?
Jumpman2k Dec 23, 2010 11:34 AM
Hrmm, I was under the impression CR's did have a spare, but either way, here is something to consider from the Electronics forum:
Flat cover:
https://www.s2ki.com/forums/index.ph...ic=214535&st=0
Semi-related -- amp rack:
https://www.s2ki.com/forums/index.php?showtopic=232978
OldDog Dec 23, 2010 01:10 PM
Thanks Jumpman2k, that's what I was looking for.
zeroptzero Dec 24, 2010 06:27 AM
the CR uses the same bulged panel as the other S2k's oddly enough. I was wondering if you could push the bulged area inwards so ti bulges the other direction. I removed my spare tire a while ago and replaced it with a pump and sealant system much like the CR uses.
© 2026 MH Sub I, LLC dba Internet Brands
