Ok, this is really cool! I have the black/red interior. This will really kick it up a notch. Its a dd, so belts get dirty with time and use. Fresh belts will be nice.
I'll wait until its time for the top. Maybe buy a set of used belts so I can send in ahead of time, so no downtime when doing top. |
Originally Posted by Car Analogy
(Post 24610080)
I'll wait until its time for the top. Maybe buy a set of used belts so I can send in ahead of time, so no downtime when doing top. You can actually access these quite simply without removing the top at all. They are tucked right behind the roll hoops. You have to remove the roll hoops to access the bolts to remove the seatbelts. You can put the top down and access all you need from there. Remove seats, remove plastic panels that allow you to get to the roll hoops, remove trunk trim to allow access to back of inner panels, remove roll hoops, seat belts completely accessible. NOTE: WHEN I SAY ROLL HOOPS, THIS IS THE METAL ROLL BAR HOOP AND THAT PLASTIC THAT SURROUNDS IT! THERE IS NO REASON TO ATTEMPT TO REMOVE THE PLASTIC FROM THE ROLL HOOPS! LEAVE THE PLASTIC ALONE! |
This is on my to do list too.
Good to know, thx!
Originally Posted by 9KEVERYDAY
(Post 24608583)
They have a Website you can purchase them from. I highly recommend emailing them first so they can send you samples. Colors can be different between the real thing and whatever display you may be looking at.
https://www.safetyrestore.com/seat-b...or-color_match This code may still be in effect to save you some cash, I used it with my order: Get 25% OFF custom color seat belts with promo code GOONZQUAD at https://www.safetyrestore.com/content/74-colored-seat-belts Found another code in my email as well: RESTORE25 And thanks for the 25% coupon - I used it Thanks |
Thank you for sharing this. Your results look phenomenal!
I am in love with these seatbelts and for how cheap it is for such a tasteful mod, it has to be done. 80$ a belt might seem like alot, but its something you use every time you drive and makes it that much more unique. i want the black with yellow, to go with yellow CR stitching doors. damn.
Fast forward 4 years, price is now $99.97 per belt and the best news......the 25% off code (restore25) still works!
Does anyone know for sure if belts from any year s2k will work in my '00? I'd like to pick up extra belts to do this and leave my oem belts alone. |
LHT said there are two different belts; up to 05 uses 1 style and past uses a different. See video above.
Originally Posted by Dibsen
(Post 25028927)
