Upgrading to 06 Radio Door
#22
Just did this. Took about 5 minutes to get the pin out. The wire hanger was exactly small enough in diameter to go through the center of the pin. Took a while to get it out.
Also when I put the whole assembly back in the car (door, trim and all) I found it easier to put the top (vent) part in first and push the bottom in. Tried the bottom first but it is hard to line up the bottom clips.
#25
Received 1,561 Likes
I just put in a CR "carbon fiber" type door in my 09. I found some coat hangers are thicker than others. I just broke off a piece and worked it. Once the pin was out a little, I used a needle nose pliers to get it out the rest of the way.
#27
Since I recently did thus project as well (CR door into my 06) I will chime in and say that I couldn't get the pins out for the life of me until I wd40'd the holes where the pins are and used pliers to grab the hanger so it didn't slip out of my hand.
#29
The instructions worked well for me. Did this last year but I'm pretty sure I used a thick-ish coat hanger to get the pins out and a roll pin punch (the proper tool) to replace. I installed one of the "CR" doors to blend better with my all-black interior.
Did this at the kitchen table.
-- Chuck
-- Chuck
#30
I just did the CR door swap this week. I don't know what they meant by pre-load on the spring, I just installed it as I figured the parts would fit. Everything seems to work fine.
