S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
What You Can Do To Modify Your Interior
Old Oct 11, 2017 | 09:59 AM
Curated Content Editor's Avatar
IB Staff
Default What You Can Do To Modify Your Interior
By Brett Foote
It's not like the S2000 interior is bad, but you can always make it better. Here's how inside.
Old Oct 11, 2017 | 04:19 PM
zeroptzero's Avatar
Interior mods are something you appreciate on every drive, providing an upscale feel and utility to our dated oem interiors for relatively little cost. My recipe has been:
Custom thicker leather steering wheel, custom leather sunvisors, carbon fiber center console cover, custom leather shift boot, custom elbowpad, extended floor mats, spoon mirror, extra 12 volt outlet, upgraded head unit and speakers with added rear speakers, custom leather door inserts, modifry organizer, LED multicolour instrument cluster, moddiction shift knob, and Muz trunk saddlebags. I've been extremely pleased with all of my mods.
Old Oct 13, 2017 | 04:29 AM
JoePhotographer's Avatar
Upgrades, so far, include replaced the MY07 OEM black seats for MY07 OEM Red/Black seats, with Red/Black door panels, leather shift boot, upgraded radio, extended floor mats, and upgraded all interior lights to LED, including trunk and license plate
Winter projects include, leather armrest, and LED lighting under the dash. I have several other updates to the car pending (fog lights, stub radio antenna, etc).
Desperately looking for a spare set of MUZ trunk saddlebags.
Old Oct 18, 2017 | 07:45 PM
shins's Avatar
anyone know where i can get an oem/aftermarket armrest? mines falling apart
Old Oct 18, 2017 | 09:12 PM
hecash's Avatar
Veteran: Marine Corps
From left to right looking frontward.
  1. Full conversion from Black to Tan interior fittings
  2. Door JBL mid-woofer speakers (L/R)
  3. Door JBL tweeters (L/R)
  4. Door JBL CrossoversConverted black interior to tan interior (L/R)
  5. A-pillar boost gauge
  6. Multi-Gauge (oil & water temp, oil & fuel press., air fuel ratio) integrated into audio control cluster
  7. 5.5mm 12VDC power outlet for heated clothing (jacket/hoodie)
  8. Custom full-length Coco floor mats (Calico)
  9. Bluetooth microphone mounted to top of steering wheel garnish
  10. Rear JBL tweeter/mid-woofer with crossover (L/R)
  11. Door activated foot-well LED lighting (L/R)
  12. Tan leather clad dash clamshell garnish (L/R)
  13. Seat headrest insert cushions (L/R)
  14. Seat headrest rear garnish painted tan (L/R)
  15. Rebuilt/fortified Seat Bottom Bolsters (L/R)
  16. Seat belt lock
  17. Custom map/document pouch mounted below rear speakers
  18. Customized steering wheel boss with Cruise Control mounts
  19. Momo Steering wheel
  20. Customized Honda horn button
  21. iPhone/GPS/Back Up Camera mount ball fitted to gauge bezel
  22. Power and rear iPod cable from aftermarket head unit wired through dash center outlet
  23. Interior light converted to LED
  24. Radar detector power wiring behind front roof rail garnish panel
  25. Radar detector mounted directly to roof rail garnish panel
  26. Radio door modified to allow use of USB Thumb Drive
  27. Aftermarket Bluetooth Head Unit
  28. Custom removable Cup Holder
  29. Countersunk shift knob
  30. Custom leather shift boot
  31. Center console converted to AP2V2 from V1
  32. Center console defroster button converted to garage door opener function
  33. Center console storage area lined with rubber padding
  34. Custom arm rest
  35. Modifry console organizer added with rubber padding
  36. Dual ignition-switched USB outlets
  37. 12 VDC Constant Power Outlet (powers adapted battery charger for impact wrench at track and AC power inverter)
  38. Modifry Dash Control Audio Interface
  39. Modifry Shift Beeper Unit
Trunk Interior
50 LED trunk lighting strip
WiFi Transmitter for Rear Backup Camera
Side webbing for convenience storage (L/R)
Wiring and power for trailer hitch
Old Oct 19, 2017 | 04:46 AM
Center console defroster button converted to garage door opener functionWiring and power for trailer hitch
Would love to see pics of the interior, since your's is (apparently) complete. I'm interested how you wired up your garage door opener?
Old Oct 19, 2017 | 11:42 AM
hecash's Avatar
Firstly, I removed the garage opener circuit from the opener remote unit. You then need to identify what switch on the circuit board is activated by the open button. The two points on the circuit board where the switch then have 18 gauge wires soldered to them.
Secondly, using an ohmmeter, you determine which of the prongs on the defroster switch actually close momentarily when the switch is pushed.
Finally, you just wire the circuit board to the prongs that you've identified and, using double back tape, tape the circuit to the underside of the console.
Old Oct 19, 2017 | 01:51 PM
hecash's Avatar
These are garage photos taken in the garage under artificial light and with sunlight coming through the window. I'll try to take some photos outside tomorrow.
Old Oct 19, 2017 | 01:57 PM
hecash's Avatar
In the last photo, you will see three metal snaps under the dash panel. There are another three located similarly on the driver's side. They are for fastening tan canvas lap blankets lined with fleece for driving in cold weather. There are also outlets (5.5mm) for DC power to supply heated jackets or hoodies (Milwaukee heated cloths are what I have but others like Gerbing make heated apparel.)
Old Oct 19, 2017 | 02:48 PM
Hfreak's Avatar
Impressive work!
