Need mechanic in Charlotte, NC area
Can anyone recommend a mechanic in the Charlotte, NC area for my 2008 SC2000 with 115,000 miles on it. Except for oil,transmission, coolant fluid and filter changes along with new brake pads and a rebuild of front brake calipers (rubber seals and boots replaced) I have done no other work on it to date. I am the original owner.
If you do not have a mechanic to recommend what should be replaced at this millage? plugs? belts? hoses?
Thanks for any suggestions
Check out this link that one of the s2ki members put together. It has all the maintenance schedules and other useful maintenance links.
S2000.club - Honda S2000 Owner's Manuals, Installation Instructions, Paint codes, Service bulletins AP1 AP2
I’d suggest checking out some of the DIY links and YouTube videos to do some of your own work. The S is a fairly easy car to work on, even if you’ve never done anything like that before, because that is how I was. I’ve saved a ton of money and learned a whole lot doing my own work.
Good luck.
Good luck.
clarkster009
12-17-2011 11:36 AM
DJT
08-22-2011 07:13 AM
jdmgpw04
06-19-2006 10:11 PM
autophiliac
05-09-2006 12:14 AM
