Aftermarket headers help with battery heat shield
Hello world
I need help I have been searching on google but can’t seem to find the help I search for.
I picked up some Skunk2’s headers and I read that the
black OEM heat shield that protects the battery / fuse box area from the heat coming off the engine.
Wont fit back on after installing the headers what’s the best route to go to protect ac lines fuse box and battery.
Would The J’s racing heat shield from Evasive work well for my problem Or is their any vendors on forums like alloy still produce parts for protecting stock battery location and fuse box please post link or pm
thank you in advance for any help that anyone can provide.
The oem battery/ fuse box heat shield or js racing
You have with your headers also is it possible to pm or post photo
I got the info from here 4th post by “legros”
https://www.s2ki.com/forums/s2000-un...-tips-1033868/
thank you again
thank you again
thank you again
also i purchased a J's racing shield and returned it because the bolt holes did not line up and the bends were wrong
Can you get a top view of the factory battery heatshield and headers?
I wanna see clearance if you don’t mind
and you also have the alloy battery heat cover
also thanks for letting me know on the js racing saving me money
the guy in the post said “Cannot reinstall “
thats the only post I came across noting that
I don’t want to work double so I been stuck there trying to find help on google but couldn’t
that’s the only thing holding me back from the work
I’ll give it a attempt tomorrow hope all is well I’ll post photo of my dirty stock engine bay once completed if completed
Might you say no issue then it’s a go lol
thank you again
I was stressing on not being able to run a heat plate for my fuse box and battery and ac line thanks for your help
I’ll be doing the work later today on a lift hope it goes well
also how can I post photos on here that way I can add photos of the work/ finish product once done
I also have a vents on my hood which might help with the heat
