Ballade Sports Adjustable Cam Gear - Preview - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Modifications and Parts
Reload this Page >
Notices
Old 02-02-2017, 12:42 PM
Banned
Default Ballade Sports Adjustable Cam Gear - Preview
Hi guys,
What do you think of our new part? This is our new Ballade Sports Adjustable Cam Gear. It will be able to advance or retard intake and exhaust cam timing up to 3 degrees simultaneously. We are currently doing some vigorously testing this before we decide to release it for sale. The cam gear will come fully assembled with the cam idler gear and front cam chain sprocket. It is made out of hardened steel matching the same HRC rating as OEM Honda equipment. Thanks for checking this out. Feedback is welcome.
BalladeSports is offline
Old 02-02-2017, 01:24 PM
ES2K's Avatar
How about individual adjustable cam gears for those who only want to adjust one of the cams? Sell intake and exhaust cam gears separately.
ES2K is offline
Old 02-02-2017, 03:14 PM
jackmugen02's Avatar
You can buy Toda Racing adjustable Cam pulleys for about $360 each from RHDJapan.
jackmugen02 is offline
Old 02-02-2017, 05:25 PM
Banned
This product is meant to be able to adjust the cams together. Why adjust one cam and not the other? For example, if a stock engine received a fresh valve job where the cylinder head had been milled. Once the head is installed the distance between the head casting and the block is going to be closer thus leaving the timing chain the same length. This product will help the engine assembler put the timing scribes back to the original position like before the resurface of the cylinder head.
Gotuningunlimited.com shows the Toda gears being sold as a pair intake and exhaust for $1,016.50.
Go Tuning Unlimited
Of course we understand, an advanced engine assembler is going to like the option of two traditional cam sprockets with full range adjust-ability to increase or decrease overlap in cam profile. But not everyone wants to spend that much money for cam gears. Skunk2 has dual cam gears as well retailing for $524.99.
We believe most of the F20c and F22c engines in the world are still using OEM camshafts so the need for two adjustable cam gears is not always necessary. Our product can get the user's cam and crank timing back into OEM standard in a more simplified manner for those with over stretched timing chains, or resurfaced cylinder heads or decked engine blocks.
Old 02-02-2017, 09:58 PM
flanders's Avatar
I thought the Ballade non adjustable timing chain gear already used the optimum setting?
flanders is offline
Old 02-03-2017, 08:44 AM
Banned
Just because the iphone 7 is out doesn't mean the iphone 6S wasn't a good phone.
Old 02-03-2017, 08:55 AM
Former Sponsor
Would you be able to adjust this gear with out taking the timing chain cover off? Also during your testing what gains are seeing through tuning?
Tougefactory is offline
Old 02-03-2017, 09:11 AM
That made me lol, good one!
Car Analogy is offline
Old 02-03-2017, 09:12 AM
S2000Craig's Avatar
Yup RHDJAPAN.COM has Toda cam gears for 300 and something I ordered a set last November if the price is right for this I'm interested.
S2000Craig is offline
Old 02-03-2017, 10:05 AM
Banned
Yes, once the gear is installed you can adjust it by loosening the locking bolts. Then you will be able to turn the crank manually in the direction of the desired cam degree increments. We have seen 6-10 whp increase in power and an increase of the torque curve coming on sooner. The performance advantage of this type of product is dependent on the engine tuner and builder. This product gives the user the ability to fine tune the engine, just as the competing products like Toda cam pulleys and Skunk2 cam gears.
Quick Reply: Ballade Sports Adjustable Cam Gear - Preview
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
