Best Intake/Air Filter
Site Moderator
Realistically what car analogy said is correct. No matter the intake you gain maybe a few hp at the wheels but the sound and look and maybe a little weight savings it really the benefit you'll see. The one exception is the arc intake which has been shown to lose power. You may want to look at the comptech/Ct engineering intake. Costs a little more than the k&n but larger piping, velocity stack, looks nice.
With a tuneable ECU (like with FlashPRO and a 2006 or later car) there is appreciable more power in the midrange (power under the curve) when VTEC can be dropped to the 3600rpm range. But this isn't cheap HP. FIPK + high flow cat + a bit better exhaust + FlashPRO + Gernby road tune adds up to the few ponies gained but they're in the midrange and noticeable. No before and after power runs but others who have driven my S2000 are impressed with the power as am I. More expensive per pony than superchargers but the entry fee there seems to be at least $4000.
-- Chuck
-- Chuck
Site Moderator
You can achieve almost all of that with a drop in filter, test pipe plus the tune. Aftermarket intake and exhaust really aren't needed. The biggest gain is midrange from lowering vtec.
seajay2525 (07-16-2021)
If you do all these things and are smart about where you spend your money where your DYI isn't possible. You can see a solid 15-20whp through the top half of the rpm range spending no more then about $500. If you have invested in some form of piggy back or EMS to lower vtec already, then those gains will be seen down further in the mid range for a fatter power curve. An F22 with larger TB is going to get bigger results from a well thought out intake.
I have recently just redesigned my set up with a HPS intake, which is a 3.5" opening transitioning to a 3" at TB with a 4" velocity stack with 3.5" mid pipe. The foam Comptech SC filter I was planning to repurpose is actually too restrictive now, causing a vacuum above 7k rpm, yet down under that my afr has gone lean. This tells me I have improved flow through the entire rpm range, and so much so that the filter cant keep up in the top end so I'm ditching it and moving to a larger KN style. Previous intake was stock intake with a KN drop in. the other provisions for cold air and all other mods I listed were previously done. No dyno, but real world measurable changes in AFR and Vac.
Most people with the stock intake box go with OEM or K&N/AEM dryflow filters. The latter can be cleaned and reused. If you got the coin, Spoon makes an air filter as well for the OEM intake. The aftermarket options may increase throttle response. Check the list of official stickys at the top of this forum for other similar threads.
