Brakes - replace rotors and pads myself?
Old 09-26-2017, 05:00 AM
starchland's Avatar
Permatex ceramic brake lubricant made my hp+ and DTCs so silent I forgot about them
Old 09-26-2017, 10:52 AM
DefSport's Avatar
Get the proper type of screwdriver for your Japanese car and the rotor screws are cake:
Amazon Amazon
All the "philips head" screws on your car are in fact JIS screws. When using a JIS screwdriver, there is no cam-out force, and they're all suddenly easy to take out. The mad JDM Vessel screw driver above can also be hit on the back to rotate out stubborn screws. I got the 145k mi original screws off my S2000 with mine. Well, one had rusted enough to the rotor that I had to weld to it, as the cross was continuing to torsionally twist the screw face off without breaking free. But if you can remove it mechanically, the above screwdriver will do it.
It's also just a really nice screw driver to use on a daily basis. I love mine.
Old 09-26-2017, 12:18 PM
flanders's Avatar
Good info and a nice looking screwdriver, might need to get one of those
Old 09-26-2017, 12:26 PM
engifineer's Avatar
Received 1,187 Likes on 921 Posts
Originally Posted by DefSport
Get the proper type of screwdriver for your Japanese car and the rotor screws are cake: https://www.amazon.com/Vessel-Megado...is+screwdriver
I saw those screwdrivers reviewed on AVE (cool youtube channel for us garage geeks :P ) and will be ordering some. They apparently are pretty durable and work well.
Old 09-26-2017, 12:29 PM
engifineer's Avatar
Originally Posted by Bruunz
You will also need a tool to push back the rear pistons. I use one of those cube things without much hassle.
http://images.superstreetonline.com/...ess_piston.jpg
I still do not know why anyone ever designed calipers that way. It is just dumb and more hassle. Not sure why they ever came into existence honestly, but honda seems to like them! My other cars just have standard discs in the back that you service the same as the fronts
Old 09-26-2017, 01:01 PM
Former Sponsor
THMotorsports's Avatar
A 3/8" drive ratchet also works
Old 09-26-2017, 06:39 PM
rpg51's Avatar
OEM rotors? Remember - just doing spirited back roads in the hills of Vermont.
Old 09-26-2017, 06:47 PM
vasquezgno's Avatar
I use centric premium blanks rotors
Old 09-27-2017, 11:02 AM
Jah2000's Avatar
I thought re-installing those retaining screws aren't really necessary?
You can also drill them out if they get stuck.
Old 09-27-2017, 01:59 PM
Car Analogy's Avatar
Received 1,304 Likes on 987 Posts
Not at all necessary. However I personally prefer to reuse them, so rotor stays put whenever I'm messing with the caliper.
I find it a lot easier to keep my greasy fingers off the freshly cleaned rotor surface if its nicely held in place. It just seems to make the whole reassembly process easier to me if the rotor isn't moving around as I try and slide everything back in place.
Quick Reply: Brakes - replace rotors and pads myself?
