Bride Gias II leg room
I recently bought a set of authentic Gias II seats with Bride LR rails for both driver and passenger. I'm 6'2" and about 195 so I do fit. The only question I have is I noticed that although I sit much lower than stock (Low Max tech), I feel as if I've lost a bit of leg room. Perhaps it's the angle of the seats but I noticed that my knees are only an inch from my ignition. I'm wondering if (although following explicit instructions for the rails), there's an ability to change the mounting holes on the rails to have the seat go back further? I remember seeing a row of holes on the rails that make me feel as if I could mount the seat further aft.
I also noticed that at full rear adjustment, I can still recline the seat quite a bit. Which leads me to think that I can probably go further?
Has any one else had leg room loss with this combo?
You might be able to, but if so, not by much. The bottom of the seat dips down in between the 4 sides of the rails.
Do you have the standard cushion or low cushion? i always recommend the low cushion because it doesn't prop your knees up like the standard cushion. Google Bride low cushion vs standard cushion if you don't know what i mean.
Thanks for the response, Chris. I was wondering about this as well. When I got home, I noticed that I was pretty much at the limit of how far the base of the seat can go back but I still had room to recline a bit. So are you saying that using a low cushion might give me some additional leg room due to changing the angle of my knees?
Indeed. Yeah, I was doing a bit of research about possible "fixes" without mutilating the seats. The part number I'm looking at is P03ACO. Not sure if Evasive has any. I've only seen it at Nengun's site and you already know what shipping is like through them.
I was also looking into BRI-A15NPO. Those are the seat rail adapters that add 20mm of height. I don't think that'll help but was also a consideration. I'll just have to find anyone that distributes the low-cushion, stateside.
The cushion looks right. Just remove your current cushion and replace with a small folded towel to see if that helps at all. Not sure how raising the seat 20mm would help though!
contact Lot USA or I believe kami speed. I know Lot USA is an authorized importer. RHD Japan should have these on their site as well.
Kami Speed (06-19-2019)
Kinnersly
Australia & New Zealand For Sale and Wanted
03-29-2010 02:33 AM
CaseyGW
Member S2000 Classifieds and For Sale
02-27-2010 10:31 PM
