C.A.R.B Cats Nowhere To Be Found
Old 11-09-2018, 11:24 AM
XSV
XSV's Avatar
Question C.A.R.B Cats Nowhere To Be Found
Anyone else in CA notice this? Every retailer I've checked with is out of stock for at least 4-5 weeks. I've checked Napa, O'Reilly, Autozone, Rock Auto, Advance, and even Honda dealerships. Luckily I have other cars I can drive to work but does anyone know what's going on? Did all of our cats die simultaneously? XD
*Edit - I found a dealer that can order one. FOR $2,100...
Old 11-09-2018, 03:08 PM
s2000ellier's Avatar
https://www.ebay.com/itm/173603311048
https://www.ebay.com/itm/292304577203
Old 11-29-2018, 09:00 PM
DaFastOne's Avatar
You can try carbcats dot com it’s a database site that list all CARB approved cats. It’s not a retail site, but it lets you know if there is a manufacturer that makes a cat for your vehicle.
Old 12-03-2018, 09:15 PM
silhouette's Avatar
the part you want is https://magnaflow.com/products?partNumber=546261
Amazon Amazon
seems like there are plenty available...
Old 12-04-2018, 05:30 AM
Chuck S's Avatar
Received 1,127 Likes on 991 Posts
Just curious how anyone knows the catalytic converter is CARB compliant (or not) when it's shrouded by the OEM heatshield and the car passes all the smog tests.
Old 12-04-2018, 07:31 AM
JamesD89's Avatar
I'm fairly certain it's still compliant without the heatshield, I haven't had any issues.
Old 12-04-2018, 08:14 AM
Chuck S's Avatar
There's a Berk high flow cat hiding inside that heat shield which you didn't see and was the point. I doubt it's CARB approved but how is anyone to know without disassembly if it passes the emissions testing?
-- Chuck
Old 12-04-2018, 08:22 AM
JamesD89's Avatar
Oh, well that works too but only if your HFC doesn't trigger the secondary O2 sensor and other monitors. I used to run a 63mm Berk with the OEM heatshield before switching to a Gernby exhaust and could never get the secondary O2 CEL to go away without disabling it in Flashpro, which would have lead to a failure come smog time.
It's definitely worth a shot, but not a guarantee.
Old 12-04-2018, 11:03 AM
s2000Junky's Avatar
That's what $10 02 bung extenders are for.
Old 12-04-2018, 12:26 PM
JamesD89's Avatar
Oh I tried those. CEL kept coming on after a couple hundred miles. Dunno what my issue was but that shouldn't deter the OP from trying at least.
Quick Reply: C.A.R.B Cats Nowhere To Be Found
