clutch install questions
Ok so please don't bash me I'm quite confused and worried here.... did a clutch install on my 05 ap2. Resurfaced flywheel. Did 500 mile break in and now when I'm sitting at a stop light or in my driveway and when the car is under load I.e. over 5700rpms the clutch appears to not be engaging fully or something. Please help. What did I do wrong or what could be going on in there?
That would be my next step. If there is air in the line, the slave cylinder won't be able to have enough throw to completely disengage the clutch. Check for signs of fluid leaks while you're under there.
I've only seen bent fingers on pressure plates twice in my lifetime, but I've seen the hydraulic part of a clutch setup fail / leak / etc OFTEN!
You should be fine.
You should be fine.
