Clutch pedal plastic grommet
There's a plastic grommet that goes in the red circle in the attached picture. My question is what's it for? I'm not sure how long it's been since the piece fell out but I haven't noticed anything weird with the car.
In this thread you can see the white plastic piece that's missing in my pic.
There are two clutch switches on that pedal. One is for Cruise Control - when you press the pedal the CC disengages. The other is the Interlock switch, which enables the ignition/starter to click over only when the clutch pedal is depressed.
Top one (I) is the Interlock
Bottom on (B) is for the cruise control
It's a safety feature and I would recommend you get it replaced.
Can this cause your car to not start? I know it’s a silly question but about an hour ago I drove my car, working completely fine. I get back in it and now it won’t start. I saw a bunch of plastic pieces on the floor and saw this groomer was missing
Three year old unrelated thread bump, but whatever.
The grommet in the photo at the top of this old thread is for the cruise control interlock grommet. The other switch is the starter interlock, and has its own grommet.
As already mentioned by others, if your plastic is from the clutch starter interlock grommet, that would prevent your car from starting. It would be exactly like if you tried to start the car but forgot to press the clutch pedal.
As a temp fix until you can replace the grommet, you could do any of the following work arounds to be able to start the car: (important, with either of the first two of these workarounds, if you accidentally leave the car in gear, it will take off on start and crash into whatever is the most expensive thing nearby. Always make sure its in neutral first!)
Bypass the interlock switch. You can search for many diy on how to do this, but basically its temporarily remove electrical plug from the back of the interlock switch, and stick a piece of wire or paper clip into the two leads of the removed plug, so they are connected to together. Now the car will start.
Rig something up so that the interlock switch is always pressed. Like tape it down or something.
Make a spacer of some sort and fix it in place with like duct tape or whatever so that it presses on the switch like normal.
Hey guys so this just happen to my car, I attached a photo of how mine look cause it seems like it still has the plastic grommet on it but the brake lights are still on. Unless I have the wrong section lol
Clutch switch has nothing to do with brake lights. Check the switch on the brake pedal (green/silver with white harness clip). It uses the same plastic bumper, and yours does not appear to have one.
Start without pressing clutch
