Defective Dual Invidia N1 Exhaust??
I just installed a dual invidia n1 on my 06 s2000 and on first start up i noticed its more quite then a lot of other ones that i have seen. Its quite and deep and not raspy at all. Its no where near loud. Is this normal? Is there some kind of break in time that is needed for this exhaust? Has this happen to any one before? Maybe i got a defective one? Any input would help.
Thanks
Thanks
You think it is defective because it is not overly loud and raspy? So you bought it to be obnoxious.
Are you running the factory cat, hfc, or a test pipe (60mm or 70mm)? A 70mm test pipe will make it to where everyone in your general area will get a headache after a few minutes of driving next to you. The factory cat keeps the noise levels in a somewhat acceptable range.
Site Moderator
Is this just on start up idle? Most exhausts don't sound crazy till you drive the car. Ditto on the question about if you are running the oem cat or test pipe. Don't worry it'll start falling apart and sound like a clapped out civic in no time.
I have the stock cat and invidia resonator. Iv seen others that have the same setup as mine and its much louder then mine. Mine is really really deep and sounds nothing like an s2000. And this on start up and while driving. While driving the tone doesnt change, it stays really deep and as i climb up in the rpm it gets quitier.
I previously was straight piped so this is nooooo were near obnoxious. It is really deep and doesnt change in sound at all, it actually gets quitier as i go up in the rpms. My thing is iv seen many others with the same setup, freshly installed it theirs is way louder then mine. Mine doesnt even sound like it would be an invidia n1 its that quite.
Site Moderator
Right now i have stock cat, with invidia n1 exhaust no silencers. What if i did a resonator deleted and ran the n1 mufflers in the back with a stock cat?
