Depo tail lights Hyper flash
Hey guys just bought a set of depo tail lights and the blinkers are hyper flashing. At first it was only the passenger side, but after unplugging and plugging eveything back they now both are hyper flashing. However, when the emergency lights are on they blink at normal speeds. Anyone know why this is and how to fix it? Any help is appreciated. The car is AP1 if that matters.
jimboslice (04-14-2020)
Bump. Tried to switch the postive and negative on the blinker connection but still hyper blinks. Also bought a resistor from autozone which did not work either. Anyone know whats wrong? Plugged in my OEM AP1 tail lights back in and it blinks fine, only hyper blinks when the DEPO tails are plugged in.
Sponsor
You'll need a set of hyperblink fixers. I've fixed the Depo tails before.
Regular ones: Turn Signal LED HyperBlink Fixers - $4.00 : JS2K.com!
Premium No-Splice Harnesses: Premium Plug and Play Turn Signal LED HyperBlink Harness - $14.99 : JS2K.com!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
hmmm, that's interesting, do you have a video of this? I don't think i have this problem, but would be interested if what I have is not built in. I also have depo tailights on an AP1. On my second pair because my first pair condensed under the lens. I did notice there was an addition of a relay in my second pair. I can't find pics of old tail lights vs new tail lights though
Sponsor
If you purchased something similar elsewhere, I'd suggest checking your wiring. These have fixed hyperblinking issues on Depo headlights previously.
__________________
_________
_________
Sorry if im just not understanding, but the plug and play harness does not appear to fit into the depo turn signal plug by looking at the picture on the website? I am currently using my OEM harness which is plugged into the depo tails (all of them fit but it hyperblinks)
