DIY: TL Brembo Caliper Conversion
#21
Mr. Grieb, just a heads up so you don't run into a catastrophic failure, when milling ~7.5mm the metal on the ears breaks through to the other side. I discovered this last week when we were milling the calipers to get them centered on the rotors. I'm not sure how much force it would take to break or crack the ears completely but I would HIGHLY suggest you reinforce the mounting ears by welding on the backside(inner part) of the caliper. I know yours didn't break through as you only milled 7mm, but that means you have only .5mm or .020" thickness in the center. I've already welded mine and they are off to get powder coated. Forgot to take pictures of after the welding but here is a couple right before I got them welded. When welding on the back side it's a bit tricky as the corner of the brake pad is pretty close but you have enough room to get at least 3mm of thickness and being that its in the corner and can go up the side some it adds a LOT of strength to the ears.
I know pretty much everyone else is just milling 7mm and I haven't heard of any failures, but this is a serious concern especially if someone were to run particularly sticky tires on the track that gives that extra grip and a lot of added stress on the caliper ears
#22
Mr. Grieb, just a heads up so you don't run into a catastrophic failure, when milling ~7.5mm the metal on the ears breaks through to the other side. I discovered this last week when we were milling the calipers to get them centered on the rotors. I'm not sure how much force it would take to break or crack the ears completely but I would HIGHLY suggest you reinforce the mounting ears by welding on the backside(inner part) of the caliper. I know yours didn't break through as you only milled7mm, but that means you have only .5mm or .020" thickness in the center. I've already welded mine and they are off to get powder coated. Forgot to take pictures of after the welding but here is a couple right before I got them welded. When welding on the back side it's a bit tricky as the corner of the brake pad is pretty close but you have enough room to get at least 3mm of thickness and being that its in the corner and can go up the side some it adds a LOT of strength to the ears.
Thanks for the post! I'm getting mine milled tomorrow. How much did you mill? Did you go more than 7.5mm? How much did the machine shop charge you to do the work? So I have an idea of what to expect.
#23
