Dyno Proven ARC/Invidia & ARC/Greddy TIC
Hi
My Dyno result with ARC Intake, Invidia TP and 2 exhaust invidia dual and greddy tic single. I thouth to have more power on single exhaust ?! What do you thing ? Mayby ARC intake is not good enought ?
The arc intake has been proven multiple times to lose power. It is purely a cosmetic addition, which is why it is not very common.
Can you explain the dyno a little more. What parts were on when it ran 249 and what was on when it ran 256?
so many variables to list why you saw a "power" change. Could be your mods just do not work well with one another. Instead of looking at the power number, look at whether or not you had gains within your powerband. Like dc2 said that intake does nothing for performance, however, you will have a gang of teenage boys gaggle once you pop your hood
Ok...look at this
https://www.s2ki.com/s2000/topic/651...e-dyno-charts/
That is one of many dyno proven greddy gives more gain then Invidia. Most of s2ki member says single exhaust gives more power then dual and I'am looking some "mistake" on my car ?
Ok...look at this
http://www.gotuning.com/product_info...oducts_id=1283
http://www.gotuning.com/product_info...oducts_id=1009
Originally Posted by bj84' timestamp='1352023105' post='22128494
Ok...look at this
There are some duals that have gains, but overall, more singles do make more power than duals.
Originally Posted by s2cho' timestamp='1352064565' post='22129127
[quote name='bj84' timestamp='1352023105' post='22128494']
Ok...look at this
Ok...look at this
[/quote]
open the links?
dual
70mm to dual 60mm piping, dual mufflers, 102mm tip.
Power gains of 10.9 hp at 8001rpm and 6.9 lb-ft at 6256rpm.
single
70mm piping, 108mm tip.
Power gains of 9 hp at 8001rpm and 5.8 lb-ft at 6256rpm.
