Sponsored by: CARiD
End Link replacements issue
Old Nov 27, 2025 | 02:30 PM
Ehrek30's Avatar
Default End Link replacements issue
I haven’t seen a post about this, but I’m trying to refresh my suspension and I’m having trouble finding the correct front sway bar end links for my AP2.
From another thread, these should be the correct OEM part numbers for an AP2:
Front Right End Link: 51320-S2A-003
Front Left End Link: 51321-S2A-003
Rear End Links (x2): 52320-S2A-003
When I search these OEM part numbers, genuine Honda links run about $80 USD each from sites like HondaPartsOnline.
On eBay, though, I’m seeing pairs listed as “genuine Honda” for around $60 for two. The issue is that the bag shows a completely different Honda part number (51325-T2A-A01), which doesn’t match what I need and belongs to a totally different part when you look it up. The links themselves look correct — they even match the pink OEM ones on my car — but the packaging clearly does not correlate with the AP2 part numbers.
Multiple sellers are offering the same thing.
Listing example:
https://tinyurl.com/5n6u88w8
I only want OEM-style, non-adjustable links since I’m not running adjustable suspension.
My question:
Are these eBay “genuine” end links actually real AP2 parts with swapped packaging, or should I just spend the $160 on confirmed OEM links from a proper Honda parts supplier?
Thank you for Reading and your time !
Old Nov 29, 2025 | 01:22 PM
Car Analogy's Avatar
Invisible ink
Originally Posted by Ehrek30
I haven't seen a post about this, but I'm trying to refresh my suspension and I'm having trouble finding the correct front sway bar end links for my AP2.
On eBay, though, I'm seeing pairs listed as "genuine Honda" for around $60 for two. The issue is that the bag shows a completely different Honda part number (51325-T2A-A01), which doesn't match what I need and belongs to a totally different part when you look it up. The links themselves look correct -- they even match the pink OEM ones on my car -- but the packaging clearly does not correlate with the AP2 part numbers.
Listing example:
I only want OEM-style, non-adjustable links since I'm not running adjustable suspension.
My question:
Are these eBay "genuine" end links actually real AP2 parts with swapped packaging, or should I just spend the $160 on confirmed OEM links from a proper Honda parts supplier?
Thank you for Reading and your time ![/color]
Old Nov 30, 2025 | 09:30 AM
B serious's Avatar
The ones you see on eBay are likely not genuine Honda. Hence the price.
You can try searching on blackhawkjapan.com to see if they have them for less from Japan.
Are your current endlinks bad?
623baller
Jul 20, 2021 10:28 AM
Stakis
Feb 13, 2016 07:54 AM
UH-60DRIVER
Jan 9, 2016 02:27 PM
abnormals2k
May 9, 2010 06:04 PM
keenodeano
May 9, 2007 02:36 AM
