Sponsored by: CARiD
Engine bay clean up / dress up
Old Sep 2, 2013 | 03:20 PM
Wolf95's Avatar
Originally Posted by mirabileboy
I've been wanting to clean up the engine bay as well. So far I have done the following:
-cruise control delete, and swapped main throttle cable with shorter cruise control cable to lose the cable loop
-air pump delete using izze simulator
-windshield wiper fluid reservoir/pump delete (never use washer fluid anyway)
Future:
-re powder coating valve cover jdm wrinkle red, right now it's vht high temp paint.
-powdercoat radiator stays, batter tie down, and battery holder flat black
-re powder coat spark plug cover a more gold color
More info on the air pump delete using izze simulator.
And I've thought about the throttle cable loop thing for a while. Did the CC cable bolt right on or did you have to modify one of the ends?
Old Sep 2, 2013 | 04:17 PM
mirabileboy's Avatar
The cc cable fit, but it was too tight as first so it idled too high. After manually stretching it a bit, it worked perfectly. I've ran it for about 4 months now. As far as the air pump, the simulator works great, I've ran it for about 5 months with no cel...knock on wood
Old Sep 2, 2013 | 04:32 PM
Wolf95's Avatar
Awesome. I may look into finding an extra CC cable for my throttle. I can't stand the loop...
And I did some research on the air pump simulator and for 64 bucks I'm still trying to contemplate if it's worth it. I had a full tucked/shaved del Sol and I'm itching to start tucking on this car but at the same time I'm yelling at myself to LEAVE IT ALONE!! haha.
Old Sep 3, 2013 | 05:08 PM
CoolGuy094's Avatar
Air pump delete kit is definitely worth the small amount of money it costs. It removes so much crap from the bay its insane. Be sure to get one of the intake manifold block-off plate things from Puddydad to be able to remove the most stuff with the air pump delete kit.
Old Sep 9, 2013 | 05:06 PM
Wolf95's Avatar
I can make my own delete plate. Haha if I get some spare cash I may dive into it. Seems easy
Old Sep 9, 2013 | 05:23 PM
it'S2klean's Avatar
Good luck, i love the look of a shaved engine bay but i never had the means to do it myself or pay someone else to. I decided to go an alternative way
Old Sep 21, 2013 | 10:35 AM
AP1Driver's Avatar
Where'd you buy all the CF covers (minus the cooling plate)? I can't find them anywhere..?!?
Old May 24, 2014 | 01:53 AM
rk renntechnik's Avatar
Old May 31, 2014 | 07:46 PM
GrantGPW's Avatar
ill note relocating main fuse box is a nightmare for wiring, rk renntechnik whats the idea behind the extra circular tubing on strut tower
Old Jun 12, 2014 | 04:04 PM
JulioOchoa23's Avatar
Originally Posted by T-S.M.A.C
I've decided I want to declutter my engine bay, tuck some wires, move some things around yada yada. My biggest obstacle is the fact that this beast is my daily driver. This post is mostly for my record, but also for suggestions. Maybe even inspire someone to start a project like this
What I want to do:
Powdercoated valve cover (black) - done
Powdercoated intake manifold (black) - purchased a spare, already powdercoated.
Painting the spark plug cover (I was thinking orange with black letters)
Relocate the underhood horn - done, moved behind grill.
Relocate battery
Relocate underhood fusebox to passenger footwell
Relocate secondary fusebox to driver fender
Relocate cruise control to A. Driver fender or B. under crossmember
Relocate ABS to driver fender if there is room. I'll be making all new brake lines to ensure equal length
A/C lines relocated with kit (its on here somewhere, forget who makes it). I would remove the a/c all together, but as for now this is my DD
Relocate EPS module
Before - stock valve cover.
Now black valve cover and intake is cold air instead of ram. I've also removed those brackets by the master cylinder that were for a master cylinder cover that I ended up not liking.
Horn relocated
Here's where it is. I might change my mind. It's on the left.
Dude! I love the black/ gold valve cover. I want to do that my self but i want the stock ap2 gold plug cover on my ap1. It wont fit would it? Being as its from an ap2 going on to an ap1?
